Appearance: How to install Projector Halos
Old Mar 21, 2006 | 11:15 PM
cmkinzer's Avatar
I just got my projector halos in the mail today so I figured I would do a write up on installing them. First you need to remove these bolts.
03-21-061 - Chevy Cobalt Picture Gallery
Then you need to remove this clip.
03-21-062 - Chevy Cobalt Picture Gallery
I removed it here so it was easier to work with. Next remove the harness from the back of the headlight here.
03-21-063 - Chevy Cobalt Picture Gallery
Next cut the brown and one of the black wires on the small side marker bulbs socket. The take some wire quick connectors and crimp them on the wires you just cut like this.
03-21-064 - Chevy Cobalt Picture Gallery
Then do the same thing to the black and white wires on the halos like this.
03-21-065 - Chevy Cobalt Picture Gallery
Then hook up the wire harness to the halos and install the lights into the headlight assembly like this.
03-21-066 - Chevy Cobalt Picture Gallery
I then tested the halos and saw if they worked or not.
03-21-067 - Chevy Cobalt Picture Gallery
Do the same on the other side and then your done here is a couple of pics of them installed. I will have more later. Hope you like them and the write up.
03-21-068 - Chevy Cobalt Picture Gallery
03-21-069 - Chevy Cobalt Picture Gallery
You can't see the halos very well but in the dark you can see them great. I'll post night pics tomorrow.
Old Mar 21, 2006 | 11:17 PM
italstalnprd86's Avatar
pictures dont work bro..... just lettin you know
Old Mar 21, 2006 | 11:18 PM
cmkinzer's Avatar
I couldn't get it to show the pics so i put the links to the pics in.
Old Mar 21, 2006 | 11:20 PM
did you hook the halos up on your day time running lights, or on a seperate switch?
Old Mar 21, 2006 | 11:25 PM
cmkinzer's Avatar
I hooked them up to the side marker. It's always on with the daytime running lamps and doesn't flash with the turn signal.
yeah, that was the light i meant... sorry, get some night pics up asap, also are you using the stock light bulbs, or silverstars or something else?
Old Mar 21, 2006 | 11:27 PM
cmkinzer's Avatar
It came with its own lights. I don't know what size they are. They aren't 9007s. I'm gonna try to find out what size they are cause they are replaceable.
Old Mar 21, 2006 | 11:37 PM
wikkymaster's Avatar
do you know how long or how much room the projectors have in them? my HIDs are a little longer then the stock 9007 bulbs and ive heard of people having hard times getting aftermarket HID's to fit in "cheap" projectors...maybe you would know....or can i even use my HIDs with this if it comes with its own bulbs? is there a way to use your own?
Old Mar 22, 2006 | 01:20 AM
Skottish's Avatar
i dont like 'em
Old Mar 22, 2006 | 01:25 AM
Darksun's Avatar
Nice write up man! Your a tropper for doing that in the cold. I think there alright but i would still like the black ones for my car.
Old Mar 22, 2006 | 01:26 AM
cvenom2122's Avatar
Thumbs up
look great!
Old Mar 22, 2006 | 08:49 AM
tube's Avatar
I like them. I might buy them if they're HIDable.
Old Mar 22, 2006 | 09:00 AM
cmkinzer's Avatar
I would have rather had the black ones also but they posted the day after I bought mine. Which sucks. The headlights are probobly HIDable but you'll need to know the right bulb size. The 9007s won't fit.
Old Mar 22, 2006 | 09:24 AM
R33P3R007's Avatar
360 L337 User
__________________
Old Mar 22, 2006 | 09:25 AM
R33P3R007's Avatar
360 L337 User
Just inserted the links, so everyone doesn't have to click each pic. Hope you don't mind
Old Mar 22, 2006 | 09:30 AM
mcphatty's Avatar
well, now that i've actually seen them on a black cobalt, i'm gonna have to say that they're not that bad.. i might even get a pair.... if they werent 660 bucks
Old Mar 22, 2006 | 10:20 AM
celicacobalt's Avatar
cool, man how is the light output of these compared to stock? is it any better?
Old Mar 22, 2006 | 11:34 PM
Mercury's Avatar
The odds are that both the highbeam and low beam are H7 bulbs.
Also as celicacobalt asked, is the light output better than stock? I doubt it is...
Old Mar 22, 2006 | 11:51 PM
cmkinzer's Avatar
The bulbs are pretty small. And the light output is deff. better than stock. I need to adjust them better but they are great. I love em. Worth every penny.
Old Mar 23, 2006 | 09:32 AM
well thats good to hear since im not at all impressed with our stock lighting performance
Old Mar 26, 2006 | 09:36 PM
Shermen's Avatar
did thay come with a manuel to install them.
Old Mar 29, 2006 | 10:40 PM
biniecki's Avatar
I was also wonder that and if they came with the connectors that you used when splicing and wire. Also this may have been asked, but i was wondering if the day time running lights are always on like the stock headlights and if those lights on the top blinked with the blinker or if they might be the running lights
Old Mar 30, 2006 | 11:10 PM
cmkinzer's Avatar
No they didn't come with the connectors I used. You can pick them up at radioshack or something like that for like 2 bucks. And the lights on top are the blinkers. Our daytime running lights are our turn signals lit up. Our parking lights are on only at night or low light. The orange reflector has a small bulb behind it. That is our parking lights. When you hook them up hook them to that otherwise your halos will not stay lit up. They will only flash with the turn signal. During the day you leds or halos won't light up unless you turn your parking lights on in the daytime. They did not come with instructions thats why I made a how to. I figured a lot of people will be like WTF when they get them. When it comes to adjusting them, good luck, it took me a while to figure out what to turn and how and don't ask me which ones were what cause I can't remember It took alot of trial and error. And since you can't adjust them in the car, You'll become a master of taking them off you car and putting them on again.
I hope this helps you all. And I found out the bulbs are H1's so you can HID them But it will take two kits for them.
Old Mar 31, 2006 | 07:33 AM
Shermen's Avatar
Thank you for the directions. i kinda felt like a dumb ass with a laptop in my garage but it worked. the running lights did not work when i installed them but they work now. thanks man
Old Apr 21, 2006 | 06:19 PM
SS SCHGD's Avatar
Can I get them in Blue? or carbon Fiber? and can the Halos be swapped out for blue ones? what about the LED's? Thanks
