General Suspension: How to Install springs
Old Oct 29, 2008 | 10:15 PM
  #101
tru2nrtt777's Avatar
Originally Posted by shortyhend2004
yes everyone has the prob with the main strut bolt how did you get it off?
I used an impact and was on and off the trigger like a blinker. My instructor explained that a bolt being steadily hammerd on will not budge as easy as one that is allowed to correct it's own twisting forces.
Originally Posted by dragonslayer27
so for those that did it themselves.
1. how long did it take you?
2. did you use airtools?
3. how experienced are you with tools (n00b, decent, expert)?
1. 30 min for rear and test drive, 1 hour for driver side front(dropped tower bolts and couldnt find one for over 30 minutes), 20 minutes for passenger front.
2. Yes but it is highly possible to use a strap wrench or a 21mm socket with the bolt head rear end so you can get it with a wrench.
3. I have been using tools since I was 4 years old and took apart a tricycle, I have been wrenching on cars since Highschool(6 years)
Originally Posted by Jn2
there some pics, between me and a friend, we got it done in 2hrs...we used air tool and a electric impact, also before the drop i could fit my fist in the wheel gap and still be able to move it up and down, now i can only get 3 fingers on the front, 2 in the back got to love them tenzo's. now since i didnt get done late, and its saturday i have to wait till monday for a aligment
Wow... how small are your tires? I have 245/45/17's and with the tenzo R's my rears are tucking tire and my fronts are about 1/2 inch from tire to fender.
Old Mar 10, 2009 | 03:59 PM
  #102
cereal83's Avatar
Anybody know what size bolts they are? I got my springs today and want to do the install but need to know what sizes I need and is a breaker bar good enough or are power tools needed?
Old Mar 11, 2009 | 09:57 AM
  #103
cereal83's Avatar
Nobody knows the bolt sizes for this job?
Old Mar 11, 2009 | 10:06 AM
  #104
D4u2s0t's Avatar
you mean all the bolts?
any regular socket set should have everything you need. as far as a breaker bar, it will help, but some of them are tough to get the breaker on because there's not a whole shitload of room with the fender liners there.
Old Mar 11, 2009 | 10:25 AM
  #105
cereal83's Avatar
I want to try to do it today but I am scared I don't have the proper size sockets and I dunno if my tools are up to the job as they are cheaper tools. I read somewhere that the top front strut needs a 21 size socket which I don't have. I could buy one and return it after I am done or just wait to the weekend until a friend is available but thats like 3 days away still lol
edit: Yeah I just tried the top bolt and the biggest I have is 17mm which is too small
Old Mar 11, 2009 | 01:08 PM
  #106
Halfcent's Avatar
I'm old school
Please read this:
https://www.cobaltss.net/forums/how-guide-43/front-strut-spring-r-r-23418/
Old Mar 11, 2009 | 07:29 PM
  #107
cereal83's Avatar
Well I lowered the car today. Started around 11:30 and was done everything at 4:00. LOL took a long time but it all done properly.
Top strut bolts are 13mm
Bottom strut bolts are 19mm
Bolt to take top of strut is 21mm
Bolt for the rear was 21mm
All in all, looks good so far
Old Mar 26, 2009 | 04:32 PM
  #108
averagewhiteboy's Avatar
Few questions:
1) So the top plates just come right off as soon as the springs are compressed? No tools or anything necessary?
2) Will any excessive force be necessary to adjust the struts back to the point in which the bolts can be re-installed in the struts (being at the top or the bottom?
3) Is an alignment 100% necessary right away? How will it hurt the car if you don't do one? Just un-even tire wear?
4) Is this something you can do by yourself, but it'll just take longer?
5) Any special tools you need aside from a basic tool set to do this project?
6) Is the top nut difficult to remove/reinstall on the front struts?
Old Mar 26, 2009 | 05:15 PM
  #109
ddsscobalt's Avatar
1- you have to take the 21mm bolt off first
2-if you dont reinstall the top plate on right, then yes... make sure you mark everything, how you took if off so you put it on exactly right. remember.. The little lip on the top plate, you will se what im talking about.. it faces the motor..
3- YES
4 and 5- YES...air is better but ive done it with and without,, the only difference is 30 minutes of your life
6-if you have spring compressors, no
Old Mar 26, 2009 | 08:04 PM
  #110
A local shop quoted me at a book rate of 4 hours to install. Seems crazy. 200 bucks. I figure I can do this myself without too much of an issue. But do you think I should do the Sportlines and the Koni Yellows or get coil-overs? I already have the Sportlines, but I don't really want to remove and re-install everything twice, plus you have to modify the Koni's anyway.. But for install on the springs, you're looking at (without power tools, and it being a single person job), about an hour and a half to 2 hours? My friend said he'd do it for 50 bucks, but I might just tackle this myself on Saturday.. And will you notice the drop right away? My struts have 54k on them, and the springs have about 20k on them..
Old Mar 26, 2009 | 08:43 PM
  #111
silver06cobalt's Avatar
You can do it yourself ESPECIALLY if you have acess to power tools. Also a word of advice loosen the nut at the top of the strut assembly before you remove the assembly from the car. It will make your job so much easier. Remember dont jump the gun and remove it because that will be a bad no no.
Dont pay anyone to do it unless if you are just that scared to do it. I promise I havent had much experience at all working on cars and I did it on my own with power tools with not one problem at all.
the struts also should be fine. I have the tenzos and they are lower drop and lower quality springs than the sportlines and i havent blown mine yet.
If you have the money go ahead and spring for the Konis but really they arent a neccessity
Old Mar 26, 2009 | 08:48 PM
  #112
Yeah.. I'm just gonna go head and give this a shot on Saturday.. Just went downstairs to check them out (got them in today).. They're used.. They have a sort of rubbery cover over the lower part os the spring.. Is that cool? That's how I got them, so I assume it's cool.. And I'm gonna probably just add the Koni's later on.. Maybe in a year or something.. Is the camber kit necessary? I remember there being a camber kit somewhere..
Old Mar 26, 2009 | 09:05 PM
  #113
Yea you wont need that.. its the bumpstop for the rear. It should be the same thing on your car.
You will see what i mean when you get the spring off
Old Mar 26, 2009 | 09:08 PM
  #114
So I don't need the little rubbery covers on the springs? They were on there when I got them.. Or did you mean something else?
Old Mar 26, 2009 | 09:14 PM
  #115
if you are talking about the round thing that has a little titty that fits inside the coil then no you wont need it. There is already one on your stock springs you can use
Old Mar 26, 2009 | 09:21 PM
  #116
These are the springs from the guys picture thing.. See the little sleeves on them?
Old Mar 26, 2009 | 09:33 PM
  #117
oh ****... I dunno what that is.. Mine had nothing like that on em
Old Mar 26, 2009 | 09:34 PM
  #118
I noticed only the Eibachs do..? lol
Old Mar 26, 2009 | 09:37 PM
  #119
maybe just a sleeve that keeps them from making noise? I have no idea..
Old Mar 26, 2009 | 09:38 PM
  #120
That's good, because my stock suspension squeaked alot in the rear.. lol
Old Mar 27, 2009 | 08:20 AM
  #121
D4u2s0t's Avatar
exactly. so when the springs are compressed it's not metal on metal rubbing.
Old Mar 27, 2009 | 10:08 AM
  #122
Word. Me and my friend are both installing our springs tomorrow afternoon.. I'll post if for some reason I get stuck!
Old Mar 28, 2009 | 05:56 PM
  #123
Thanks for all of your help on this install.. Got it done today.. Took forever because we were using hand tools, and we got caught up on that one set of bolts, and super slowed down by the spring compressors.. But the car looks great!! Can't wait to go road these it here in a minute.. Hope the strut doesn't shoot up through my hood.. haha
Old Jun 8, 2009 | 12:34 PM
  #124
dunit121's Avatar
nice im guna do it
Old Jun 8, 2009 | 02:08 PM
  #125
07Maliboo's Avatar
well another way instead of using a spring compressor if your lazy is to loosen that bolt before you jack the car up, which slowly releases tension, then remove the strut, not as safe but I'd much rather have the spring shoot up into the wheel housing than if a spring compressor gives out or slpis, releasing in any directoin.
