Appearance: How to Make & Install Lower Grill
Old 05-07-2006, 05:59 AM
Cobalt_Supercharged's Avatar
Originally Posted by Shermen
Just did mine using this how too. the thing i big!! and its only like $8!! not to bad of an install. thx to cobalt_supercharedt
P.S. some one needs to make a how to on this but the upper grill.
No problem.
I have been wanting to try the upper grill, but have not had time with work and school. Perhaps this summer. Just a warning though, it will most likely be more complicated than the lower grill.
Old 05-07-2006, 11:53 AM
Shermen's Avatar
Originally Posted by Cobalt_Supercharged
No problem.
I was thinking that it would be way harder, but whatever you come up with I have a feling that it will be a good how too. and thanks again for the install on this.
Old 05-07-2006, 12:19 PM
mqqn's Avatar
No problem.
Hi Folks -
My local Lowes did not have the stucco mesh lath - so I am working on some stainless mesh a friend thinks he has enought to do the opening - 350 miles and the condenser looks like it was in a war.....
best regards -
mqqn
Old 05-29-2006, 11:54 AM
cross720's Avatar
thks really work well and easy...but you should buy the stainless look grill that tuner store sell it looks more finish...
tks again.
Old 05-29-2006, 01:30 PM
DTM2188's Avatar
great how to for the lower grill. keep us updated if u do the upper one too.
Old 07-06-2006, 12:03 AM
roccobladr's Avatar
is there a way to do this with the 2.4 SS? it does come stock with that lower front bumper piece.
Old 07-06-2006, 01:25 AM
I'm not positive, but I think the 2.4 also has the holes for the lower extention. You will have to take a look for yourself. If it does then you are in luck. All you have to do is get the clips or use another similar clip to hold the bottom piece.
Besure to let us know if it does in case other 2.4 owners want to do the same.
Old 07-19-2006, 11:19 PM
JRANGER's Avatar
I am getting ready to do this to my car this weekend....I bought my grill mesh at Home Depot for $4.88 in Nashville TN. But its Diamond Mesh which is sku 175404....it looks perfect and I cant wait to work on it....
Old 07-22-2006, 11:58 PM
tsunam1's Avatar
I lost my lower grille on the interstate, guy in front of me drove over what was left of a semi tire (retread) and launched it into the air. I hit the brakes but to no avail, it landed on the nose leaving a nice gouge in the paint and when it went up under the car it punched out the poorly designed lower grille. I then proceeded to drive over all of it..... So nice post, as I think your method of protecting the radiator is stronger than GM's cheesy snap in.
Old 07-23-2006, 01:28 AM
I don't know if it is stronger or not, but it is a hell of a lot cheaper to buy and replace.
Old 07-23-2006, 01:40 AM
  #36
hatrickstu's Avatar
looks good, i didnt want to mess with that, so i paid the dealer a c-note to do it
Old 07-23-2006, 10:48 AM
  #37
godsfshrmn's Avatar
Yea man one sheet of that stuff and a can of spray paint would do it at least 3 times.
Old 07-23-2006, 09:18 PM
  #38
checkmate17's Avatar
Having problems finding the mesh, none at the Lowe's I went to. Anyone have the actual name off the product tag or the part number (not SKU cause hard to pull up online).
Old 07-23-2006, 10:02 PM
  #39
Z28 SS's Avatar
thanks alot bro, mine came out perfect, Home Depot charges 7.99 though. O Well thanks again
Old 07-24-2006, 01:52 AM
  #40
I was unable to find it online. I think it is more of a regional thing. I had someone from Florida PM about it because they looked at every Lowe's Home Depot etc. to find it, but had no luck.
JC Whitney has more expensive pre-colored versions. http://www.jcwhitney.com/autoparts/B...002181/c-10101
Old 07-24-2006, 06:42 AM
  #41
I saw those going to check some performance shops here and some local hardware stores, someone has to have it cheaper then 19.99 plus shipping. Thanks
Old 07-24-2006, 07:07 PM
  #42
Found it at Home Depot, the name it goes by is Galvanized Lathe. I have the home depot part number if needed by anyone.
Old 07-24-2006, 08:27 PM
  #43
tsunam1's Avatar
I went to the gutter section and got a piece of the aluminum gutter screen, pretty stiff. with the pins through it it is definitly in there more than the original grille was and I do believe it will be harder to punch out. Not to mention the screen will do a more efficient job of stopping objects from hitting the radiator than the original "twin bar" grille did.
Old 08-20-2006, 10:37 AM
  #44
1BadBlueSS's Avatar
So where do you attach the zip ties when installing the metal mesh?
Old 08-20-2006, 10:45 PM
  #45
I didn't use any. I used all the factory trim clips.
Old 10-11-2006, 09:43 AM
  #46
Coop's Avatar
Cobalt supercgarged did you just slide the retaining clips through the holes in the mesh to secure it? How lone did you cut the mech to fit? Great write up cause I need to do this.
Old 10-11-2006, 11:56 AM
  #47
yes slide the clips through the mesh. As for size I cut mine about 5-6 inches bigger then the hole on both sides then trimmed any that showed
Old 10-12-2006, 01:39 AM
  #48
I just made and intalled my second grill on Blow 4-banger's car this past weekend. Glad I put this on here because I had to reference it again to get the size.
The rough dims are in my first post 10" x 33". That is slightly large, but better to be too big than too small. You will have to trim the corners off the bottom in order to get it to wrap under properly. Make the bends and get the top secured and then trim it until it fits.
Yes I slid the clips through the holes in the mesh. The 2 top clips are larger and require you to cut the mesh to make a larger hole, similar to as shown below.
Old 10-13-2006, 09:19 AM
  #49
Coop's Avatar
What did you use to make sure the paint didnt get scratched from the mesh?
Old 10-13-2006, 11:08 PM
  #50
I sprayed my mesh with black rubber "undercoating" That should help, but I really haven't looked at it since I put it on. Perhaps I should do that. You could probably lay down some rubber gasket material if you wanted. The places where it would scratch are not visible.
Quick Reply: Appearance: How to Make & Install Lower Grill
