Appearance: How To: Paint YOur HeadLights (lots Of Pics) 56k (mabye)
LOL ajent, i just did mine today too, broke 2 tabs, but all in all, they look AMAZINGGGGGGGGGGG!!! Im so happy with it, I used the oven, didnt take any of that **** off barely, but I got them back over the tabs, it was a pain in the ass, the whole process took about 4 hours of working time, of course we were slacking.
Yeah, I definatly don't have the patience for that, I wish I did. I need to re-paint the interior also because I made a nice little smudge when I tried snapping it back in place. (didn't wait long enough).
Why would you paint where the green is? Then your headlights would look bad and really dull. You do know that underneath that green is the reflection chrome right? Like it reflects the light and helps project it, and without it it would look like just a bulb instead of a light ^ ^
Originally Posted by R33P3R007
nice writeup. has anyone painted the whole housing. the center 2 green patches in this pig you posted
and just left the light surround and the turn signals unpainted?
no this would be left alone
as well as the turn signals. just painting the bottom of the main headlamp.
nope no sand paper needed.. i used duplicolor paint only no primer and it adheared perfict as did it to the outside of my headlights for my eyelids... ill have pics of my painted headlights and also my eyelids within the week
I got them apart much much faster this time. Took me about 10 minutes with the hair dryer running into the side marker opening. Unfortunately it melted the sidemarker lense and the reflector. I'm gonna try to repair the reflector but odds are slim. But about 20 min of work this time as opposed to 2 hours last time. Just gotta start prying at the sharp corner.
bumping....this is next on my to do list, prolly wed., n i dun wanna have to dig up the thread later
also, what adhesive should i use? caulking would work right? cuz my dads in construction, so ive got an unlimited supply to caulking
Originally Posted by red_wing_2121
How long will the 'balt be out of commission during this? Less than a day?
I am just worried that I will screw them up and end having to get new headlamps.
Which you should be doing anyways...ebay is your friend. Buying them through the dealer is like getting an ass raping.
mine was in the garage for a day and a half
i toke thm out baked them in the oven separately for 10 mins each put in oven then shut off oven dont run oven while u are doing this
then take it out and slowly pry apart using small screwdriver to losn caulh (start in corner) thn i sanded th metal down note sand again with 220 or higher cause i did it with 60 and left it and i needed a lot of paint to cover and i sanded multipe times) then use black primer a couple of times sand if u want thn put on gloss black spray paint or watevr u are using put about 3 - 5 coats on then put 2 - 3 coats of clear 1st coat wait 15 min then 2nd coat - wait 15 then after the 3rd wait (can says 24 hours but i waited like 16 hours then Clean the inside of the clear lens for fingerprint marks i didn't do a very good job and left a finger print, put caulk around assembly and put in oven ( all 3 assembly's ) then push them together put black caulk all the way around ALOT OF CAULK IS NEEDED! then reheat in oven for a couple. then let it sit for a long time ( i waited like 4 - 5 hours but u are supposed to wait longer before you put it back in your car o well so there u go hopefully that helps u out
is there a way to knock out the amber blob thing without taking apart the headlight casing? cuz knowing me, i'd eff up the oven process and not seal it right and then the next few days moisture will accumulate =(
