Drivetrain: HOW TO Replace Shift Linkage Bracket
Old May 21, 2012 | 01:54 AM
SCcobaltSS's Avatar
This is how to replace the shift linkage bracket on the transmission.
New Bracket:
LSJ Shift Cable Cable Upgrade Bracket 55563732
Old Bracket:
First take the driver side tire off.
Next locate shift bracket, it is located on the transmission connected with (2) 13mm bolts.
Next pull the shift linkage from the bracket. To do this push/pull plastic clips toward the shifter and lift on the linkage to unlock.
After linkage is removed unbolt bracket from transmission, again (2) 13 mm bolts.
Replace with new shift bracket and bolt down.
Next slide linkage into slots and clip in. No pushing/pulling of the clips needed just firmly press down, you should hear a click.
Once that is complete reinstall tire.
Should take less than 30 minutes depending how stubborn the linkage clips are.
Old May 22, 2012 | 01:36 PM
you da man
Old May 29, 2012 | 03:10 PM
Gelladuga69's Avatar
Thanks for the write up. Ordering this bracket today.
Old Jan 17, 2013 | 04:20 PM
slider699's Avatar
Was wondering if you can use the old trans mount with the new braquet?
Old Feb 10, 2013 | 09:32 PM
c130aviator's Avatar
Just did this. Took the spongy feel out of the movement between gears. Night and day difference.
Old Feb 10, 2013 | 09:39 PM
Pitbull2o08's Avatar
Does the LNF bracket fit the 2.4 LE5 F23 transmission??
Old Feb 10, 2013 | 09:40 PM
Powell Race Parts's Avatar
Originally Posted by pitbull2o08
does the lnf bracket fit the 2.4 le5 f23 transmission??
no
Old Feb 10, 2013 | 09:41 PM
AZ car, No rust. see that? amazing. C139aviator had rusted and stuck cable sleeves and thought there was an issue and maybe he was doing it wrong.
nope. rust. ugh.
so glad i dont drive my RL in the winter.
Old Feb 10, 2013 | 10:14 PM
my car was registered in NYC for four years... Definately a little salt in the bracket.. Bought the car in TX thinking I wouldnt have stuff like that. Amazingly the entire underside of the chassis is rust free. Just nooks like those spring loaded sleeves caused them to be stuck. Also everyone said pry on them and everyone that told me that was wrong, those sleeves are spring loaded, just pull em back.
Old Feb 10, 2013 | 10:15 PM
yes
Old Feb 10, 2013 | 10:19 PM
c130 aviator, the Cobalts are darn good for rust on the unibody frame. the cradle and the cabs dont do as well..
AZ cars are best lol.
Old Feb 10, 2013 | 10:29 PM
i must have had a garaged car, there isnt a lick of rust anywhere on my car. TX cars are the best. But I am a bit bias for the greatest state in the US.
Old Feb 10, 2013 | 10:31 PM
no
Anything I can do for mine?
Old Feb 10, 2013 | 10:45 PM
pull your mounts off, weld washers to both sides, reinstall, Instant solid mounts.
Old Feb 10, 2013 | 10:58 PM
gotta push out the rubber inserts if you are going to do that....
Old Feb 10, 2013 | 10:59 PM
lol, true, ehhh, just weld em up that crap will melt out.
Old Feb 11, 2013 | 11:01 AM
Will do. Thank you
Old Apr 29, 2014 | 01:22 PM
sssupercharged15's Avatar
The shifter linkage doesn't want to come off.. Any tips?
Old Apr 29, 2014 | 06:51 PM
rocco11189's Avatar
keep messing around with it. I took the bracket off and that helped a bit to move it around. Just be gentle with the linkages
Old Jun 7, 2014 | 04:11 PM
tahoeman17's Avatar
no 1st or 2nd gear
just replaced bracket now i have no 1st and 2nd gear seems to shift fine sitting still but feels like its in 3rd gear when i go to take off and stalls adjusted cables still no 1st and 2nd any help would be greatly appreciated. The trans seems to be stuck in 3rd gear any help are the cables bad or did I mix them up when I pit the bracket on
Old Jul 26, 2014 | 06:32 PM
Cobaltyme's Avatar
Plastic slide sleeves
Spent an hour and a half trying to get even one of the cable brackets to release. Slid it back and tried to pry it out of the slot. No go! WTF! I've never seen such a whacked out locking mechanism. GM must have a special fork tool to hold that sleeve back. Exacerbated to say the least.
FOUND THE ISSUE: As you access the shifter bracket through the wheel well, the cable bracket that is closest to the drivers side (the lower cable/3-4 gear) can't be removed until the cable above and behind it (1-2 gear) is released from the bracket first. The slide on the upper cable, due to clearance issues, keeps the lower (3-4 gear) cable from popping out of the bracket.
Do yourselves a favor and unbolt the upper and lower bracket assembly, pull the lower bracket out of the car, so that you can maneuver the upper cable bracket around and release the upper/1-2 gear cable FIRST. Now the lower one will pop out when released.
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
2009blackSS
Sep 30, 2015 05:57 PM
Delta coupe
Sep 30, 2015 08:11 AM
