Interior: How To: Replace a turn signal switch
Old Oct 7, 2011 | 07:23 PM
JimmiLS05's Avatar
Due to a broken switch I thought I would make this.
Needed:
- Replacement part SKU: 20940099 which I purchased from Crate Engine Depot
- 7mm socket or nut driver
- 15 minutes
First I raised the steering wheel all the way up to get at the 3 screws
From there the best way to explain it is to massage the 2 bottom column covers back and forth to unhook the fasteners on either side. The hook part of it is on the drivers side, so try and push up on the drivers side near the seam while pushing the panels together. The top section has 2 fasteners near the steering wheel and 2 more like the ones that hold the dash in, which are near the cluster. The top section I left in place, just holding it up to get at the column
From here I lowered the steering wheel all of the way. The switch assembly is held in by 2 tabs, 1 on top and 1 on the bottom. Try to push with your fingers, but if you have Jimmy Dean sausage fingers like myself, a small flat blade screw driver works.
Gently pull the assembly out of the column, being aware of the harness plug into the back. 1 tab on each plug to remove.
From here work your way backward, be sure to test the switch after hooking the harness back up before putting the column back together. Try not to break this one
Old Oct 8, 2011 | 03:02 AM
Getaway_Driver's Avatar
Awesome! Thanks for doing this write-up. My stupid turn signals either never stay on or refuse to turn off automatically. I always have to either manually turn them off myself or keep holding them down so people behind me know where I'm headed.
Looks like I now have a reason to order the new turn signal!
Again, thanks for the great DIY.
Old Oct 8, 2011 | 03:04 AM
Here's a link to the part in case anyone is too lazy to do the search for it:
Cobalt turn signal
Old Oct 8, 2011 | 03:12 AM
Murdered SS's Avatar
******* awesome doing his tomorow thanks bro. Ive been looking for a how to on this signal switch.
Old Oct 8, 2011 | 05:46 PM
CrateEngineDepot's Avatar
Great write up, not a bad job at all from what i remember, something anyone can do.
thanks for the write up.
Old Oct 23, 2011 | 01:30 PM
Refractor's Avatar
Awesome write up. The guy at the dealership tried to charge me $400 to do this LOL. I just laughed at him, apparently he didn't think it was as funny as I did.
Old Oct 23, 2011 | 05:50 PM
$400. He must of been looking for some huge comission or something.
Old Oct 23, 2011 | 08:17 PM
Refractor's Avatar
I took it in for a fuel leak, and he was visibly disappointed when I proved to him that I wouldn't be paying for it because of the extended warranty, so when I had him look at the turn signal he tried to make up for the cost.
Old Feb 9, 2012 | 10:17 PM
Josuizzle16's Avatar
god damn it i took it out and cant get it back in
Old Feb 9, 2012 | 10:19 PM
help?
Old Feb 9, 2012 | 11:42 PM
Cobalt08LS's Avatar
thats what she said
Old Feb 20, 2012 | 04:22 PM
xderekxhuggiesx's Avatar
"Gently pull the assembly out of the column" There is not enough space to pull it out because the silver trim to the left of it is in the way. How did you get pass this without taking off trim?
Old Feb 20, 2012 | 04:25 PM
JimmiLS05's Avatar
My trim has been off for a while so I didn't know it was an issue. Otherwise I'd say try moving the steering wheel to a different position. Otherwise just pop the trim off , not hard to do.
Old Feb 20, 2012 | 05:46 PM
Ahh I see, it sucked but I forced the old one out and new one in. So anyone reading this, yes you can do this without removing anything besides what is addressed in this how to. Thanks!
Old Mar 1, 2012 | 12:23 PM
New updated link
Old Mar 17, 2012 | 09:11 AM
klloyd's Avatar
I should have added this to my clutch pipe order, sometimes turning left it doesn't shut off.
Old Apr 7, 2012 | 10:53 PM
Sandroid's Avatar
This was very helpful and no doubt saved me a lot of money.
I did have to remove the trim, I could not remove the switch without doing so and I was afraid I'd damage the new switch if I had to force it in.
It does help to know the trim is only clipped in. I wedged a flat head in-between it and the dash and carefully popped it out on each side.
Pop the left clip out first and then you can pop up the right side.
Old Jul 2, 2012 | 11:13 PM
enzo182007's Avatar
Absolutely pull the dimmer knob trim... i like to use a flat head screw driver wrapped in an old sex sock.. the trim has a clip on the left and right side so a light pry from the top and pull straight out... the clips are kinda strong
Old Jul 5, 2012 | 09:25 PM
kawategra98's Avatar
sub'd
Old Jul 23, 2012 | 04:41 PM
MoJoJoSSsc03's Avatar
Sub'd for lata werk! :d
Old Sep 9, 2012 | 06:36 PM
romeropc100's Avatar
Its not absolutely necessary to pull the dimmer knob trim... it works fine by just pulling the harnesses off BEFORE attempting to take the signal switch out... then it comes out with light extra effort but works pretty smoothly.
Old Jul 6, 2013 | 02:24 PM
Import Reaper's Avatar
sorry to bump old thread but I just replaced turn signal switch in 07 cobalt lsj. Still doesn't want to auto turn off once I make the turn in either direction, is there something else I need to fix or replace? or is the turn signal I bought broke to start with?
Old Jul 29, 2013 | 06:45 PM
XStylus's Avatar
I think there's something in the steering column that sends a signal to the switch to turn off, and that's not working in your case, or so it seems. When you turn the steering wheel do you hear the "tick" that's supposed to trip the turn signal?
I'm hoping that's not the problem I've got. My turn signal switch is having problems in that it won't stay engaged for left turns, yet will stay engaged for right turns but won't auto-off. I ordered a new switch ($30 on ebay), we'll see if it fixes my particular problem...
Props to the OP for posting the pictures and instructions. That will come in handy.
Old Jul 29, 2013 | 07:12 PM
Good to know if I ever need to change mine.
Old Aug 25, 2013 | 04:43 PM
kennyb's Avatar
Cobalt collum pannels
When I put mine back on, the collar around the signal arm kept freeing itself from the control module. And the ignition has friction against the plastic makes the key harder to start the car freely.
