2.2 LAP Engine: How to Seafoam a LAP 2.2L
Old Apr 7, 2012 | 08:35 PM
Roeder's Avatar
Canada How to Seafoam a LAP 2.2L
im sure this would work for any 2.2 but Ive got a newer version so i used that for example.
before we get into it im just going to say; yes in rare circumstances this could be dangerous but like with mostly anything car service related there is always a small chance something could go wrong.
you should always do your research and use your own judgment on what you want to do and dont want to do to your balt, or any other car. other people opinions and experiences are a good thing to listen to and consider but in the end its always your choice.
and on that note every car will be different so im not responsible for any damage you might cause..
i have no complaints about it personally, i was a goof and haven't done a service like this for the past 80-90k so if anything bad would have happened im sure it would have happened to me, carbon build-ups going where they shouldn't have and all.. but i had no issue and the car runs way better now, also i put a quarter of it in my gas and the other 3/4 i put in the intake.
first off i went for the vacuum line with the seafoam in a glass jar. i took the line off and put it on backwards so i can stick one end in the glass jar to suck out the sf (seafoam). now when allowing the vacuum line to suck in the sf. you have to make sure you dont choke it so do it slowly making sure its only consuming a little at a time or if your good with understanding the sound of the way your motor idles try and go by that, you'll hear your rpms starting to fall a bit and thats when you want to back off a bit.
here are a couple pics for visual aid 8)
after youve finished off the seafoam from what ever container you have it in take the line off and put it on the right way again and let it run for a minute then shut it off to let it soak in all the gunk. after 5 or 10 minutes turn your car back on and it'll start a bit rough but it will start.
after that rev up and let the **** burn ;D oh and try and be considerate to your neighbors.. the stuff isnt the best smelling stuff around and there is a good chance you will probably smoke out the street :P
anyway hope this helps, and happy foaming!
Old Apr 8, 2012 | 08:49 PM
Roeder's Avatar
pics fixed.
Old Apr 8, 2012 | 11:23 PM
breds2k's Avatar
Awsome! I gotta do this to my car to clean out some cold start gunk given me a crappy blending noise in the morning! hopefully that will work and i dont have moderate lifter damage.
Old Apr 13, 2012 | 05:02 PM
doughboy007's Avatar
i went through the break booster hose is there a difference????
Old Apr 13, 2012 | 07:30 PM
Roeder's Avatar
not clue, but im almost sure that's the simplest way, not sure where the break booster line is. so i couldnt tell u.
Old Apr 13, 2012 | 07:51 PM
nhanson's Avatar
Also went through brake booster. I believe they feed the same - intake manifold
Old Apr 14, 2012 | 06:31 PM
its on the bottom of the intake. i couldnt get the hose you used to disconnect.
Old Apr 15, 2012 | 01:25 AM
cobythecobalt's Avatar
Man I wish this thread was here a month ago!! It took me forever to find the right hose! The brake booster and this one are basically the same. This one however is more centralized to the cylinders. It will more evenly distribute the seafoam. Plus its A LOT easier to get to!
Old Apr 15, 2012 | 08:39 PM
Roeder's Avatar
how could you not get the hose? lol its right on the top of everything and i used what was there, i didnt buy anything to do this. the clips that are on the hose are very easy to remove from the connections you push the hose down and move the tabs to the right i believe.
ill try and make a video of it if that would make it easier to show what i mean?
Old Apr 20, 2012 | 01:08 AM
i just didnt want to break it
ThoR294
Oct 4, 2015 08:44 PM
Tupp
Sep 30, 2015 08:18 PM
theamericanautos
Canadian North East
Sep 24, 2015 08:11 PM
jmelton327
Sep 24, 2015 01:40 PM
