2.0 LSJ Engine: How to Seafoam an SS/SC
2.2 Vacuum hose location
1. Find your brake booster (circled in the red) - a big round thing under/connected to your brake fluid reservoir.
2. Disconnect (at the brake booster) big vacuum hose that goes to your intake manifold (circled in blue).
3. Pour in vacuum hose (NOT THE BRAKE BOOSTER).
Alright we also need a how to on the SS/TC.
I'm thinking the line coming into the left side of the intake manifold, but I haven't checked it for vacuum.
I always remove it to change the oil filter.
Can someone confirm.
Holy Moly...Well Lets Say I Started Off With A Black Smoke As I Started Then Turned Blueish Then White For Like 2 Miles LoL...I Put It In Gas Tank, Engine Oil , & Vacum Hose... Then Went For A Oil Change...Wat A Fun Day With My Balt....Now Time To Flush The Brake Fluid & Supercharger Oil
Keep cranking at short intervals until it does. It shouldn't be able to flood the engine through a vacuum hose. Did you not keep the rpm's up while you were pouring it in? that's pretty essential.
no, i kept the car at idle. i slowly put the seafoam in. i cranked the car so much the battery is dyin lol
the car wants to start up. itll start, sputter for a bit then die. im gonna try lettin it sit for a little
Last edited by BlackCobalt707; Feb 15, 2010 at 02:44 PM. Reason: Automerged Doublepost
yea the plugs got wet earlier and i took them out, cleaned them and sanded them to get the black stuff off. didnt work. but i just got it workin. i unplugged the fuel pump relay, cranked it a few times to burn the seafoam, replaced the relay and started it. it sputtered a little bit but i gave it gas and it stayed on, **** was smokey as **** lol. thank for the helps guys
thank ya. when you said it was flooded i thought about it and was like "damn, if seafoam is in it and everytime i crank it it adds more fuel, maybe if i cut out the fuel and let it burn the seafoam it will work"
i wish you woulda said somethin hours ago lol. its coo tho. a lesson learned and somethin i can share with other people who fucked up like i did haha
Wrong
WRONG you can run seafoam in your engine oil when it is bran new i do it every oil change and proof check this out seafoams website
Its the 2nd most asked question
http://seafoamsales.com/gasoline-engine-faqs.html
