Electrical: How To: Traction Control Switch
Old Sep 1, 2008 | 09:39 PM
Halfcent's Avatar
I'm old school
There is really no reason at all to do what you are talking about. "I" or "2" simply turns off overdrive and is normally used when driving on hilly roads to prevent frequent up and down shifts. If you are just passing somebody, then just hit the gas and pass them.
Old Sep 1, 2008 | 10:28 PM
Red07SSNA's Avatar
It's not something I do usually. I just dropped it into "I" when I was going to pass@45 MPH (when the traffic was clear) and when I goosed-it the engine did not rev up quick -- felt like traction control kicked in. I tried passing again in "D" and in "I" and the engine revs quicker just leaving it in "D" when passing at speed.
Old Sep 1, 2008 | 10:47 PM
knoxbox's Avatar
what im trying to say is that the 08 cobalt ls standards specs say all gear traction control... whenever i put my car in L or I or D or N or R or Park there is no light that pops on to say traction control is off... if i pull the ebrake up one click no light pops on... so im assuming they fixed this in the 08... if thats the case then im curious if this override will turn off the traction control.
Old Sep 1, 2008 | 11:04 PM
Halfcent's Avatar
I'm old school
If the parking brake doesn't turn it off, then this won't either.
Old Sep 1, 2008 | 11:06 PM
knoxbox's Avatar
should i try pulling the abs fuses and see if that turns it on? think that might work? i just want some way of cutting the traction control...
Old Sep 2, 2008 | 09:28 AM
Red07SSNA's Avatar
Does your 08 have a manual TC button on the dash to the left of the steering wheel?
Can you check your build sheet and see if you have traction control -- or All Gear TC?
I also believe that GM has an All-Gear TC system -- maybe you got "lucky" and have that?
Old Sep 2, 2008 | 03:12 PM
knoxbox's Avatar
there is no traction button in my car... when i look up the factory options for my car on different websites they all say "all-gear traction control" there has to be some way i can disable this.
Old May 24, 2009 | 08:42 PM
Red Devil 07's Avatar
ok i just tried it and i did it in drive still had TC on is it supposed to be in L for it to work?
Old May 25, 2009 | 01:27 AM
knoxbox's Avatar
shanks unfortunately we both fall under a model that can not disable traction control and you wasted your time doing this switch... the way to see if you have all gear traction control is if you put it in I or L the traction like should come up on the dash. if it doesn't then you have all gear traction control and this trick will not work. i've not been able to find another way to disable it. don't know if there is possibly a way only other thing is maybe trifecta can disable it through their tune.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
Coballin13
Sep 25, 2015 08:43 AM
