All Engines: How To: Wire Your Fans To A Switch!
Old Jun 24, 2009 | 09:51 AM
Preston's Avatar
Many threads like this have been popping up lately and i am getting sick of telling people when they pop up. So here is a How-To for the whole forum.
How hard is this, Not Very hard. My direction might be off a little i am doing this from memory.
STEP 1:
Disconnect Your Battery, if you would like to.
STEP 2:
Unwrap the wire loom from the fan.
This will show 3 wires.
One being Purple, which is LOW fan speed
One being Blue, which is HIGH fan speed.
One being White, which is the ground.
STEP 3:
Select which wire you want to use for your fan speed. Run this to POWER. I used the jumper post (thats what i call it) right by the fuse box.
STEP 4: Then run it to your switch of choice. I am pretty sure that is all i did. I left the ground alone because it is already ground.
Old Jun 25, 2009 | 01:18 PM
Turbo06Sedan's Avatar
great how to.
Old Jun 25, 2009 | 01:37 PM
hawlyns711's Avatar
you mean run fan wire to a switch then from other side of switch to the power
xxxxsh4d0wxxxx's Avatar
Which switch did you run it to?
Old Jun 26, 2009 | 02:18 PM
Preston's Avatar
that could be too, its ******* hot out. So i am gonna look when it cools down a little bit to confirm this and get pictures up
i just bought a switch from the hardware store. I had nitrous before so i had a hole drilled into a piece my trim
Old Jun 26, 2009 | 08:40 PM
Nighthawk243's Avatar
Just make sure to add a fuse in between.
Old Jul 3, 2009 | 11:29 AM
Shogokuma's Avatar
whats this application for?
Old Jul 3, 2009 | 11:34 AM
cobalt123's Avatar
x2...
Old Jul 4, 2009 | 12:19 AM
Its to override the fan relay to allow you to run the fans at will if you need to. That way you can run the fans whenver you wouldn't normally have them on for things like track days or running from the 5-0.
Old Jul 4, 2009 | 08:29 AM
turboss09's Avatar
Anybody have this done so far and take notice how much cooler your car is running?
Old Jul 4, 2009 | 10:38 AM
Shogokuma's Avatar
yeah that would be good for waiting at taco bell!
Old Jul 4, 2009 | 10:44 AM
dunit121's Avatar
yah taco bell is the worst wait every
Old Jul 4, 2009 | 12:53 PM
mkriebs's Avatar
Now, this will work with the car off also, correct? I have been thinking about doing this so when I am in the staging lanes at the strip I can run the fans to evacuate the hot air from the engine bay.
Old Jul 6, 2009 | 02:55 AM
Looking at the write up, he has it wired to the battery post directly, so this will remain running as long as the switch is ON.
Old Jul 6, 2009 | 03:11 AM
Preston's Avatar
Yes sir. You can turn it on whenever you please
Old Jul 6, 2009 | 03:54 AM
mkriebs's Avatar
I was just clarifying since the post in the engine bay is not the battery itself. I was not sure if the car turned off power to that terminal when the ignition was shut off or not. Thanks for clarifying though!
Old Jul 7, 2009 | 01:44 PM
5hizn1t's Avatar
If you use a single pole double throw with a center off switch you can wire one way to factory wiring and the other to battery positive. That way if the switch is one way the computer operates the fan like it's supposed to and then if you want it on or off all the time you can switch it to that.
like this one from radioshack
Old Jul 7, 2009 | 01:59 PM
mkriebs's Avatar
Good idea! I was trying to think of how to do that, but the furthest I got was thinking how i could run a switch like that and have control of low and high speeds.
Old Jul 10, 2009 | 02:24 PM
mkriebs's Avatar
So, I have this thought out a bit better. I am going to splice in before the original relay, so I can trip the relay manually. This will allow 2 things, first, it will be more reliable, since I will not be running power directly to the fan, and second, it will allow the fans to come on automatically.
Old Jul 12, 2009 | 03:03 AM
Billsac's Avatar
Perfect
Old Jul 21, 2009 | 05:39 PM
06cobalt_ss's Avatar
What pathe did you follow from under the hood into the cabin to mount the switch?
Old Aug 3, 2009 | 09:36 AM
akbar87's Avatar
Wouldn't this possibly burn up something if you had the switch on and the relay on the car came on?
Old Aug 15, 2009 | 02:45 AM
cradleoffear06's Avatar
Originally Posted by Preston
STEP 3:
im sorry i am horrible with wiring and electrical stuff. but Shouldn't you run the wire you choose to the Acc. on the switch and power to the power part of the switch from power you get from some where else??
Old Aug 16, 2009 | 01:48 AM
anyone??
i plan to do this tomorrow...
Old Aug 16, 2009 | 02:30 AM
Maven's Avatar
Yeah this is an epic f*cking how to. No fuse, hot side controlled, direct power, awesome, just asking for people to A:kill their battery, B: burn their car to the ground.
