General Suspension: Installing rear sway bar.
Old 09-08-2006, 01:43 AM
redlineblueline's Avatar
This is the process for installing the Progress rear sway bar, also used for the Torque Forward rear bar, not sure about ST. And yes I have both on and you will see how. There are probally easier ways to do this.
This is what you get.
The bolts are very easy to cross thread into the nut flange. BE CAREFUL. They will break off of the flange and are a PITA to get back off.
1. Jack up car. Put on stands.
2. Take off rear wheels.
3. Line up bar.
4. Line up nut flange. You will see a hole under the bottom spring mount.
Use a 3rd jack stand to hold bar inplace.
5. Thread bolts into one side.
6. Thread bolts into other side. You may need to use another jack to force the shock up to line up the holes.
7. Torque to 45 ft/lbs.
8. Wheels back on.
9. Lower car and rock suspension, enjoy.
Old 09-08-2006, 02:03 AM
Stilgar's Avatar
I got a rear sway bar coming. How hard is it to install? Those 2 lil pieces make it look kinda difficult lol. When I put one on my Zx2 is was just take out the old one and bolt the new one on.
Old 09-08-2006, 02:19 AM
You slide the flange in and it pops into the holes where it needs to go.
Old 09-08-2006, 05:01 AM
SK63's Avatar
That seems easy enough.
I hate to sound stupid, but what does a sway bar do exactly?
Old 09-08-2006, 08:43 AM
xspyder85x's Avatar
helps with body roll i believe, same as a strut brace, and lowering springs
Old 09-09-2006, 04:01 PM
mjbroeker's Avatar
Nice write up. It is good for showing how easy it is to just use the holes that are already there and tighten up 4 bolts. This can be installed w/o jacking up and taking the wheels off.
Old 09-10-2006, 04:32 PM
nomoreavril's Avatar
wow thats easy. i like buying easy mods lol. maybe now i wont be discouraged to buy one
Old 09-11-2006, 12:43 PM
rcmpayne's Avatar
where can you get a sway bar in canada
Old 09-11-2006, 05:19 PM
mestrocks's Avatar
do you need to take off the tires????
Old 09-14-2007, 10:36 AM
Fresh's Avatar
neverenoughauto.com
Old 09-20-2007, 01:04 AM
c130aviator's Avatar
Is the sway bar attached to the body of the car? I dont see a step for that part. If the bar is not attached to the body its not doing anything to stop the car from rolling in the rear.
You need two bushing that have flanges to bolt to the body of the car. Then it may help... The attachment points look flimsy using those flat pieces of steel between the bar and the spring perches.
Not bashing on ya bud, just suggesting some stuff.
Old 09-20-2007, 08:47 AM
its a unibody so bracing the semi-independent rear will in turn brace the rest of the car. you could cut the rear "axle" peice and have an independent rear so basically it makes it more solid and less independent in the rear
Old 09-20-2007, 08:53 AM
originaladrian's Avatar
wow this thread has a shi*t load of clicks
+rep BTW for a good thread
Last edited by originaladrian; 09-20-2007 at 08:53 AM. Reason: Automerged Doublepost
Old 09-20-2007, 09:17 AM
CobaltPerformanceParts's Avatar
Nice writeup. Very good pics to go with it.
Old 09-20-2007, 09:21 AM
rep me for my awesomeness
Old 09-20-2007, 09:23 AM
Sadly i dont know how to +rep
Old 09-20-2007, 09:24 AM
click the little scale at the bottom of my little post box in between the green circle and the exclamation point
Old 09-20-2007, 09:31 AM
ahh haa. Thanks!
Old 09-20-2007, 09:33 AM
rock on dude
Old 09-20-2007, 01:35 PM
cobaltguy88's Avatar
can u get these on a 2007 Cobalt LT 4 dr?? pm me plz
Old 09-20-2007, 01:38 PM
they fit all cobalts, g5, pursuits, ions
Old 09-20-2007, 01:41 PM
Yup they fit on all models.
Old 09-20-2007, 01:52 PM
Super_SS's Avatar
its a super easy install if u have a friend to help u out..kinda hard to hold it up and screw the bolts in at the same time...took me about 15 min to install with a friend,i have the progress sway bar
Old 09-22-2007, 01:34 AM
Think of our rear axle like a solid rear axle from wheel hub to sheel hub. Pretty much the same concept. Mount the center that is attached to nothing... Like this.
If you mounted the center of the roll bar in two places to the unibody with these
it would then be a fully functional swaybar. The points on the body of course would have to be reinforced but then you would see what that thing could really do.
Right now that sway bar is doing little to nothing but adding weight.
Great right up though by the way.
Old 09-22-2007, 08:01 AM
g5mike's Avatar
nice write-up.thanks,i will refer to this when doing mine.
Quick Reply: General Suspension: Installing rear sway bar.
