General Suspension: k sport coilover install(56k get a beer)
ok the silver thing you see it the "nut" that i was talking about. it has a rubber pad underneath it, that is what the spring rests on. the sleave it is threaded to actually goes over the bump stop. hope that helps.
hey i installed mine the other way around.....(in the rear)
then u wont be able to adjust ride height!? the reason the pic looks so confusing is bc in the pic he has the height adjusted all the way up so that it would be easy for his spring to seat since the supplied springs are half the height of any other spring......i just installed these the other day if u r struglling with the rears give up now bc the front is a whole different beast to tackle if you ever want to get them riding right......i iwsh i had taken pics but grease on hands and cameras dont mix so i skipped the photo ops.....
well i jacked my car up once again nd pulled the spring nd adjuster out nd looked at em. the only i was able to install both pieces is with threaded part of the mount pointing downwards into the spring...the way jimbo has it might wrk but as far as height adjustment...no way
ok it's simple dude, put the spring on the lower perch, take the sleeve and put it on top of the spring with the lip up so it and the adjustment ring and rubber pad resting on the spring, lower the car making sure the bump stops stay inside the sleeve. after that adjust the ride height you want.
yeah i saw gravana tuning was selling the camber plates for the b&g ones. I don't know if i have to buy them but you would think they would say something about that when you buy them. i wish there was a how to for these ones
