2.0 LNF Engine: ZZP's ZFR Turbo Installion
Old 03-18-2014, 05:46 AM
  #126
Wert842's Avatar
The bpv.
Old 03-18-2014, 07:02 AM
  #127
tomj77's Avatar
Originally Posted by Wert842
The bpv.
We talking about the same thing? I don't think bpv goes there that doesn't make sense. Bpv would be connected same as stock it wouldn't be connected to the air intake side of the turbo, it gets connected to the bpv solonoid like stock turbo is
Old 03-18-2014, 09:35 AM
  #128
Wert842's Avatar
Show me in a pic. You said the fitting for a hose or something. Only fitting on the intake side that I do recall is below the intake and that's the bpv. If you're talking about the solenoid that is on the back side of the zfr and there's a fitting that looks like it needs connected, its just a breather.
Old 03-18-2014, 09:38 AM
  #129
tomj77's Avatar
Ya the breather would be what I'm talking about. I don't really like it sitting open like that, I'm gonna put a little filter on it.
Old 03-18-2014, 12:32 PM
  #130
dcrep06's Avatar
are you talking about the gray plastic piece?
Old 03-18-2014, 01:26 PM
  #131
tomj77's Avatar
Lol man I'm gonna post pic when I get home. Zzp said it's for the hose that goes into valve cover. So that means they relocated it from where it is on stock turbo. Cause it is a quick disconnect fitting. So then what's the port on the zfr inducer.
Old 03-18-2014, 01:28 PM
  #132
tomj77's Avatar
Never mind I looked at the pic on page one , it is for the line that goes to valve cover, or in my case, oil separator. And I'm guessing the other port is speed sensor port
Old 03-18-2014, 01:43 PM
  #133
tomj77's Avatar
Does the oil feed for new turbo hook up to same place as stock? Saw a different write up that said u take plug out of block under turbo there and plug up stock location. I'm hoping not cause I'm using the port under turbo for oil pressure gauge sender.
Old 03-18-2014, 04:40 PM
  #134
dcrep06's Avatar
Oil feed is on top of the turbo with the stainless flex line. And connects down to the drivers side of the block.
Old 03-18-2014, 06:12 PM
  #135
tomj77's Avatar
thanks everyone for the help, just making sure I got everything down before I do my install
Old 03-19-2014, 06:18 AM
  #136
dcrep06's Avatar
No problem. Print off this how to, it's a very simple install and the OP did this perfect. Only issue you may run into, but I doubt it cuz I think they fixed it, is the exhaust housing clearance. I installed mine last July and had to trim down one of the heat shield tabs on the mani so the turbo sat flush. Other than that, no issues.
Old 03-19-2014, 07:03 AM
  #137
tomj77's Avatar
I bought a manifold gasket just in case. I'm gonna use my tablet , I have an arm I can attach to pretty much anything , so I'll have it hanging under the car with me with everything I need. Paper will get dirty and wet and is just in the way lol
Old 03-19-2014, 07:32 AM
  #138
dcrep06's Avatar
ah ok, that works as well. but yea, you shouldnt need to take off the mani, i didnt need to. you will see the tab im talking about when you take the heat shield off, you should be good though, havent heard of many people needing to grind it down. but my papers didnt get dirty lol, minus the small corner where i flipped the page. id just be worried about hitting the tablet lol.
Old 03-19-2014, 09:49 AM
  #139
tomj77's Avatar
Well usually I just look at the next step when I come out for something and remember it. But I don't think I'll have it under the car, it will be on the side of the car where I can see it. I may take a rotary tool to the tab just in case. Better then haveing to take Turbo back off. Should only take a few minutes. No biggy
Old 03-29-2014, 01:30 PM
  #140
Ronn2005's Avatar
Out of curiosity does the oil return gasket need to be drilled out with the 21/64 th bit?
Old 03-29-2014, 02:00 PM
  #141
Wert842's Avatar
Gasket will need to be drilled just a tad bigger.
Old 03-29-2014, 02:27 PM
  #142
Ronn2005's Avatar
How did you drill it? I just destroyed my first one. I lightly drilled it and the bit bent it up. I tried to practice on the other side and it was the same result.
Old 03-29-2014, 04:11 PM
  #143
Wert842's Avatar
Just put a little bit in a bench vice and held the other end with pliers and drilled it. Worked fine for me. Kinda frayed a Lil bit but snipped some off.
Old 03-31-2014, 06:50 PM
  #144
tomj77's Avatar
whats to correct torque for the coolant banjo bolts
Old 03-31-2014, 08:53 PM
  #145
dcrep06's Avatar
dont know if there is a torque spec on them. but dont tighten them too hard, you snap it, have fun getting it out lol. def wont be fun.
Old 04-01-2014, 12:00 AM
  #146
tomj77's Avatar
in gm online thing from eautorepair its says 16 ft pounds on the page with all the torque specs, and then in the instructions on how to replace turbo it has for dealers it has 26 ft pounds. idk which one is correct. or shall I just go by what I think is good. don't see why it needs to be that tight.
Old 04-01-2014, 07:58 AM
  #147
dcrep06's Avatar
16 sounds about right, i dont think it takes much at all. if you have an adaptor, use a 1/4 ratchet lol. id just be careful with them. better too little than too much, because you can always get back under the car and tighten them back up. go in between though id say.
Old 04-01-2014, 08:25 AM
  #148
tomj77's Avatar
I have a torque wrench adapter for 1/4 and 1/2 wrenches. Little computer that plugs into ur socket and driver on other end , so no issues there. I'll just throw that on when I take off the bolt from stock turbo, cause it works in reverse as well since it's attached to normal socket, and I'll see how many foot pounds it takes to break it loose , that should give me the info I need
Old 04-01-2014, 09:18 AM
  #149
dcrep06's Avatar
that sounds like a good idea to me lol
Old 04-02-2014, 08:01 PM
  #150
tomj77's Avatar
I had 2 and tried this today, tried it just by holding it on wood with hand drill. bent the first one. second one I took a c clamp and lightly clamped it to wood and used drill press. worked perfect. also cut a nice gash in my thumb from doing it with hand drill.
Quick Reply: 2.0 LNF Engine: ZZP's ZFR Turbo Installion
