INTENSE-Racing.com Intense Racing is a proud Supporting Vendor
INTENSE Stage 4 HELP!
Old Aug 19, 2006 | 11:18 PM
  #51
M88ArRamadi's Avatar
Hey vandy0419---->> You ging back to INTENSE for them to check your car?? We have the EXACT same numbers, mods, and problems.
Edit: I'm going to buy HP Tuners if INTENSE walks me through the tuning, and helps me fix the problem
Old Aug 19, 2006 | 11:22 PM
  #52
vandy0419's Avatar
I don't know, I think I'll just use my money to go in on HP Tuners and get someone's tune flashed on it that no one has had problems with.
Old Aug 19, 2006 | 11:25 PM
  #53
I have the original GM flash and thought of doing that. I decided that I should learn how to tune.
Old Aug 21, 2006 | 08:51 AM
  #54
vandy0419's Avatar
I'm going to ask around some people I know and see if they know of any differences between the RL and Cobalt flashes...
Old Aug 21, 2006 | 11:04 AM
  #55
that sounds good.....I'm going to do the same for now
Old Aug 21, 2006 | 11:29 AM
  #56
vandy0419's Avatar
Well talked with a few guys on the RL forums and it ends up INTENSE doesn't do much with the VE table and that is what everyone else is changing almost immediately.
Old Aug 21, 2006 | 12:01 PM
  #57
06blackg85ss's Avatar
I was under the impression that the VE table only comes in to use if the maf fails....
Old Aug 21, 2006 | 03:34 PM
  #58
I'm buying HPT tomorrow depending on scott or todd's response. WOW that crap is expensive. 650+shipping
Old Aug 21, 2006 | 04:19 PM
  #59
vandy0419's Avatar
I'm fortunately going in on it with 3 other people so its less than $170 each
Old Aug 22, 2006 | 09:42 AM
  #60
CobaltSS422's Avatar
is that for the Pro version?
Old Aug 22, 2006 | 09:52 AM
  #61
vandy0419's Avatar
Yeah...there you can hook up a wideband and it will read it out on HP Tuners...
Old Sep 1, 2006 | 01:45 AM
  #62
Alright INTENSE though I might be over-reving the sc and recommended me to down grade to a 2.6" or 2.7". SO.........I bought a 2.6" pulley and ......even worse than I thought ..... 14 psi!! I removed ALL parts of the stage 4 checked them and re-installed them. I, once again, ripped apart and re-installed the sc and by-pass valve.
Before the downgrade I COMPLETELY bypassed the by-pass valve. I went for a quick ride and my car **** it-self. Said something like "torque managment power reduced" I had NO POWER and shitty idle. I shut it off waited a minute and turned it back on. I was able to make it home. The car felt like it had Hella power UNTIL I went WOT.
Old Sep 1, 2006 | 07:44 AM
  #63
djt81185's Avatar
Try running a compleely stock air box for one
pull s/c and clean all gasket mating surfaces
ensure no belt slip...check idler and pulley for dust
Run a manual bypass on s/c
if its hitting limp mode im betting its something to do with ur airbox
Dan
Old Sep 1, 2006 | 11:52 AM
  #64
Dan
1. I have a completely stock airbox....I had to remove the air-box mod because I was getting the LEAN code when I first got the s-4.
2. I've removed, tore apart, cleaned, inspected, re-assembled, and installed the sc 3 times now.
3. No belt slip.....no squeaks or black dust (have GM S-2 belt)
4. Ran a manual boost by-pass ... little to no difference
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
