INTENSE-Racing.com Intense Racing is a proud Supporting Vendor
The OFFICIAL Aeroforce Interceptor Gauge Problem Thread
Old Jul 19, 2006 | 11:44 PM
  #76
06black's Avatar
Originally Posted by sethallen
before the LCD screen wouldnt display information. Now it displays information, but it takes up to 10 seconds sometimes to refresh itself. Like when coasting, PSI is like -9. Well if you go WOT, it still says -9 for up to 10 seconds before updating to 12, 15 PSI etc. There is an option to change the data rate (how fast it updates) and i have it set to the fastest rate...
whats the Refresh rate set at?
Old Jul 20, 2006 | 12:03 AM
  #77
silverSS's Avatar
planning on buying one from intense, hopefully it will work, im trying to see if they have any of the older editions, without the shift lights, beacuse those seem to be problem free.........
Old Jul 20, 2006 | 12:07 AM
  #78
forcefedjunkie's Avatar
Be sure that the connector is seated all the way in the OBD2 port, and that none of the OBD2 port pins are pushed in, which is not that uncommon. We're sending you another anyway just to be sure. This has no relation to the 12v power issue.
Todd
Old Jul 20, 2006 | 02:04 AM
  #79
SSweet06's Avatar
I just got mine from Intense last week and installed it on Sat. I love it except I also have the problem with the very slow refresh rate. I notice you guys are located in Columbia Station. I live like 5 minutes from you guys. Can I maybe stop by sometime and have you check it out and see what you guys think?
Old Jul 20, 2006 | 02:06 AM
  #80
06black's Avatar
you can adjust the refresh rate in the gauges menu,
set it to "1" and you'll be happy!
Old Jul 20, 2006 | 02:33 AM
  #81
SSweet06's Avatar
Done that already, its still too slow in my opinion
Old Jul 20, 2006 | 11:01 AM
  #82
Rogue's Avatar
Just filled all of our red gauge backorders today with more on the way, we sell these things faster than Aeroforce can stock us Kudos to Todd at Aeroforce for being very active in taking care of customer issues, they are the epitome of vendor's we like to deal with.
Old Jul 20, 2006 | 11:47 AM
  #83
firesting's Avatar
Safe to buy one for my 06 ss-sc? I bought my car about 2 months ago. Any problems still?
Old Jul 20, 2006 | 11:49 AM
  #84
distillion's Avatar
listening...
Old Jul 20, 2006 | 11:51 AM
  #85
R33P3R007's Avatar
360 L337 User
I called and ordered mine today, and intense said that todd was adding some precautionary thigs to the gauges and this shipment should have no problems. but I have an 05 so mine should be fine anyway.
  #86
denny's Avatar
Todd
Todd I read alot of your posts and am very impressed with your great customer service.
Old Jul 20, 2006 | 12:02 PM
  #87
player_1's Avatar
wait a minute, you mean that the 05's never had problems.
damn I could have orderd this long ago.
Old Jul 20, 2006 | 12:03 PM
  #88
06black's Avatar
to all who where asking if its safe to buy yet....
the answer is YES!
I did the testing on the gauges with the "fix" and so far its gone 3 weeks and NOT A SINGLE problum!
Todd and aeroforce has fixed the issue and this is such an awesome gauge that it doesnt make sence to NOT get one!
Old Jul 20, 2006 | 02:27 PM
  #89
These gauges display data as fast as the car responds to the request. The Cobalts I've seen are in the 7-10 update/second range at the "1" data rate.
Old Jul 20, 2006 | 02:30 PM
  #90
PM sent.
Todd
Old Jul 20, 2006 | 03:22 PM
  #91
Xenozx's Avatar
the answer is YES!
I got mine back yesterday hooked it up and its been working great ever since. In the box with my returned interceptor was a check for return shipping which was pretty kool, as I didnt even ask for it back. I am happy to have my interceptor back and working in my car and hopefully it will stay that way from this point forward
Old Jul 20, 2006 | 05:08 PM
  #92
sethallen's Avatar
the datarate is set to 1, which is the fastest. I also tried it at the other settings, but same issue. I definetily do not regret getting this gauge. If there EVER is a problem, i know for a fact that Aeroforce will properly take care of you. They have EXCELLENT customer service. As you guys have read, I noticed the problem yesterday, and Todd has already put a new gauge in the mail. I will let everyone know. I am sure it is something simple, and I doubt every gauge will have the issue.
If you are considering buying the gauge...quit thinkin, and buy it! Well worth the money. Aeroforce definetily backs their products 100%
Old Jul 20, 2006 | 05:58 PM
  #93
StinkBOMB's Avatar
I already did a search and this thread came up so here goes...does the Interceptor display A/F ratio? I was looking at the features list on Intense.com and was too retarded to figure it out. Does anyone have the right answer?
Old Jul 20, 2006 | 06:02 PM
  #94
sethallen's Avatar
i unhooked all the clips, checked them, and plugged them back in. Still refreshes slow at times. I'll see how the new gauge works as soon as i get it
Old Jul 20, 2006 | 10:07 PM
  #95
M88ArRamadi's Avatar
The AEROFORCE Interceptor Scan Gauge does the following:
RPM
MPH
Intake Air Temperature pre intercooler
Intake Air Temperature post Intercooler *
Mass Air Flow Sensor Frequency *
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure in PSI (Boost pressure)
Supercharger Inlet Pressure *
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Instantaneous fuel economy
Horsepower
Analog input #1
Analog input #2
* Critical tuning parameters not found on most other scan tools for the Cobalt/Redline!
Old Jul 20, 2006 | 10:55 PM
  #96
The gauge has 2 analog inputs, either of which can be used to connect to the output of a wide band kit. You still need the wide band O2 and controller, you'll be connecting the 0-5v output (just about every wide band kit has one - just be sure it is a linear output - which just about every one is except the Zietronix) of the controller to our gauge. You'll then be able to read and log the A/F ratio on the Interceptor gauge.
Todd
Aeroforce
Old Jul 22, 2006 | 02:23 PM
  #97
player_1's Avatar
hey Todd
any Idea if they fixed the Issues with the LC-1?
Old Jul 25, 2006 | 04:22 PM
  #98
Originally Posted by player_1
hey Todd
I sent my LC-1 back to Innovate to get the analog out fixed, have not heard back from them yet. I hear that they have supposedly corrected the issue with the outputs failing.
Todd
Aeroforce
Old Jul 25, 2006 | 04:29 PM
  #99
player_1's Avatar
thats good, I wanted to get a Wide band to go with my aeroforce gauge. and had wanded to use the LC-1 because it's supposed to be one of the highest resolution, and cheaper then buying other widebands with gauges.
Old Jul 25, 2006 | 09:25 PM
  #100
R33P3R007's Avatar
360 L337 User
WTF.... HELP. I tried constant and only on with the key, but still the screen comes on and off randomly
