JBP 4-Pass Intercooler
#77
Originally Posted by rlinbatonrouge
How can you send coolant that way? I can't visualize how it will flow 4 times through 4 cores with a dual inlet. Duel inlet means flowing into two cores at once, right? I'm still lost.
You just use 8 Laminovas in a parallel inlet 4 pass series arrangement. That would double the area of the intercooler. Think outside of the box !
Pierre
#78
Originally Posted by Tomtwtwtw
Here's how I see it...the single inlet snakes the fluid through 4 cores in series, hence the fluid spends a lot of time in the intercooler. The more time it spends in there, the hotter it gets and the less effective it is at cooling the air.
The dual inlet runs fluid through all 4 cores at the same time, but straight through, (like a 4 lane highway as opposed to a 1 lane twisty road) so the fluid is circulated faster through the intercooler, meaning it doesn't heat up as much, and because of that is more efficient at cooling the air.
I'm no expert on this, but it sounds like that's what he's trying to say. Some e-whack me if I'm way off on this.
#81
I will break down the properly posed questions and ignore the filler:
Whats the difference between the stock pump and jbp pump?
STOCK PUMP:
Stock Pump = Centrifugal, Butyl Elastomers affixing neoprene impeller radial design..
Stock pump flow, using metered coolant we measured to be 24.5L/min. Total Head, unknown, per m/h20.
JBP PUMP:
Centrifugal design, Bronze Impeller, Impervious to debris, damage. NPT connections and 39~47L/min flow. Pressure testing to be @ 0.15 - 0.3 bar implied. Total Head 2.87M/H20
Whats the difference between the stock intercooler and your intercooler?
STOCK SETUP:
Single Inlet/Outlet
Serial Run
Out to Aftercooler
Rubber Lines
JBP SETUP:
Dual Inlet/Single Outlet
Parallel Run
Out to Surge Tank (optional)
Out to Aftercooler
Bolts up to stock location
Braided #12AN Lines
FLOW PATTERN DIAGRAMS:
Stock flow description: I will assume that stock flow is understood by all and doesn't need further explaining.
JBP flow description: The top inlet handles the top two laminovas, The bottom inlet handles the bottom two laminovas. Output is channels into one fitting.
LAMINOVA CORES:
Stock Laminovas: I will assume that people who are "confused" have disassembled the stock laminovas, examined their material construction alleviating further description.
JBP Laminovas: GM Stock laminovas are fitted with a new layer of "material" (We CAN NOT mention) over the exposed air charge. There is also a 4 additional metered pressure orifices placed directly in the flow of coolant to maintain our desired coolant flow. Laminovas are also repositioned to achieve the pressure difference required by thermal dynamics to achieve better cooling.
Keep the proper questions coming, I'll be able to answer them tonight.
edit: pics were not coming up...
STOCK PUMP:
JBP PUMP:
STOCK SETUP:
Single Inlet/Outlet
Serial Run
Out to Aftercooler
Rubber Lines
JBP SETUP:
Parallel Run
Out to Aftercooler
Braided #12AN Lines
LAMINOVA CORES:
#83
Civil post:
Why is a new pump necessary for this modification? The stock pump should not be working any harder than before. It would be moving the same amount of fluid, but the total pressure will be a tad lower due to running the cores in a different configuration. Additional pressure from the outlet notwithstanding.
I'm only guessing at the configuration, but i'm assuming they would be running in a half/serial half/parallel configuration. Two sets of cores in series running in parallel.
Also, I understand that you can't mention the material (trade secrets and all that), but you will still be limited by the heat transfer properties of the core materials, no matter how many layers of secret materials you put on.
#84
#85
Originally Posted by shabodah
Heat transfer is going to be dependent on core materials, sure, but when your surface area is limited, it can make sense to use a different material in the area to transfer the heat to the core. This is why some heatsinks are made of aluminum, but the surface that touches the component to be cooled is plated in copper. It's all about using the surface area as best as you can.
At least thats how my mind is wrapping around it. Ugh...I have to go and look over my heat transfer notes now.
#86
See, what I don't get is that while the copper will heat up quickly in your scenario, it will still transfer at whatever conductive rate aluminum has. It will be helpful at first, until the copper gets heatsoaked waiting on the slower aluminum.
Geez, this is at least the 2nd time that they have "released" a part without anything to back it up. Next time, they need to wait and have proof of gains, people aren't willing to shell out money for a part, just because they claim it works.
(That would be a constructive comment... )
#87
LSX RWD S/C conversion
Originally Posted by automobiliben
Wouldn't be too hard to figure out, just two materials with different thermal conductivities. If I recall, to calculate the total conducitivity, isn't it just the inverse of the squares?
#88
#93
Originally Posted by victory_red_SS
After all the BS in this thread, don't expect JBP to be answering questions any time soon.
#94
Originally Posted by SS_SC_Cobalt
Victory, honestly they have to have a thicker skin than that to be a vendor, there will be doubters always, if they want business they have to power thru and ignore the dead flesh, lol
Besides, getting into a fight on a forum is ALWAYS a losing situation for a company, whether they win or lose the fight...
Like all products, we will know its true value once someone buys it and tests it...
#95
Originally Posted by DanteMustDie
ha... it's probably not that they don't have a thick skin, it's just that bitch fights aren't the most professional way to sell a product. So they present the product, then give technical details when asked about it in a proper manner. Don't expect them to answer to the many morons who blindly attack (or ask stupid questions) just about every product that comes out and then whine that no one makes aftermarket parts for them anymore...
#96
well we still have to know when we can ge em...I have an intercooler ready to go...
#97
At this point our lee-time for pump restocking, as given by the manufacturer is, 4-5 weeks. At that point, intercooler kits will be manufactured upon order.
#99
You are better off phoning JBP and talking to Mev. Right now they are all going full bore on my engine and "wasting time" with forum clowns who weren't buying the product no matter what, is a waste of JBP's time. The people who want JBP's products will phone and get real time answers to their questions.
