JBP Big Brake Front Kit!
Nice!!!!!! You guys just don't know how much I will be buying from you in the future!!
Get the backs done and give a cross drilled, slotted, or both option for the rotors, and different colored calipers. The J hooks like interesting, I do like the classic cross-drilled & slotted though.
JBP FTW!!!!!
JBP Decals too!!!! for 30 hp
(j/k)
JBP FTW!!!!!
The back kit will be just a rotor replacement without a caliper swap. The rear brakes are very good for complementing the front kit in bias. So this makes for a cheaper overall kit. Only J-Hooks will be provided, cross-drilling or slotting is not an option, adding either of those would just satisfy looks.
I would assume these would work on the 2.4 SS as well since they have the same bolt pattern and the wheel should still clear
AMAZING, I LOVE THE LOOk
outstanding keep up the good work fellas, I cant wait to get some of your stuff soon
Yes, the stock 18" rims will fit our brakes. After all the system has been tested already. I believe the smallest rim size you can go to is a 17" rim. The smallest offset you can get away with is around +35.
