LSJ T6061 Aluminum Crankshaft Pulley
Old 05-08-2008, 09:33 AM
  #276
Omega_5's Avatar
Originally Posted by Joeyavhu
Okay, so I asked the dealership, and they told me the first path is 74 ft/lbs and the final path is 75 degrees.
Simple question, the degrees is what makes it a TTY bolt, right? Like, after it is torqued down, I turn the wrench another 75*, right?
Not all TTY bolts need to be turned the extra degrees... but most do have that spec.
Yes, you need to turn the bolt 75* after the initial torquing.
It helps to have a degree attachment. They run about $20-30 at most tool supply businesses.
Old 05-08-2008, 09:48 AM
  #277
RuSSo-29's Avatar
OK, I'm picking one of these up this weekend.... where can I get on the these bolts and what kinda bolt is it? Sorry, I just don't feel like reading through all the pages...
Old 05-08-2008, 10:01 AM
  #278
Joeyavhu's Avatar
Okay, cool thats what I thought, I may have to pick one up for future reference then. Thanks.
You can get it from the dealership. It took about 3 days for mine to get here. Only 6.36.
Old 05-08-2008, 10:06 AM
  #279
RuSSo-29's Avatar
Thankx man! Couldn't have been more simple!
+1 fake rep!
Old 05-08-2008, 10:08 AM
  #280
Joeyavhu's Avatar
No problem. Lol, I haven't seen that rep system in a while.
Old 05-08-2008, 10:27 AM
  #281
3fo893013L's Avatar
I hate to ask but any results in yet?
Old 05-08-2008, 12:18 PM
  #282
RuSSo-29's Avatar
Yea, Rep died. But I still keep up with the Invisa-rep! lol
I think it was like 5whp
Old 05-08-2008, 02:34 PM
  #283
Joeyavhu's Avatar
I just got mine in today, so I will let you know how it goes after tomorrow. Sorry, but no before/after HP numbers, only the butt-dyno for me. Lol
Old 05-08-2008, 02:40 PM
  #284
Jumpin Fool's Avatar
Thumbs down
Which means you won't be able to tell a damn bit of difference and will probably be dissappointed.
Old 05-08-2008, 06:40 PM
  #285
Joeyavhu's Avatar
Ehh... Even if I cant notice a difference as far as feeling, I am heading back to the track on Wednesday, so, hopefully I will see something there.
Old 05-11-2008, 02:23 AM
  #286
Joeyavhu's Avatar
So, I just finished putting it on. Really easy, no more than 20 minutes with a buddy and some air-tools.
A hint, when putting it back on, instead of using a pry-bar to keep the flywheel from spinning, just stick the car in 5th gear and have your buddy push the break pedal down. This is more than enough resistance to get you your 76 ft/lbs
I personally think there is a difference, especially where the car starts to pull. That "weaker" spot around 2900-3500 is now gone, or at least reduced significantly. I will be able to tell any other difference after Wednesday's test and tune at the track.
Old 05-11-2008, 02:28 AM
  #287
Rattlesnake Race Shop
USMCFieldMP's Avatar
Nifty. I've debated getting this.
But instead of putting the car in 5th gear... you should put it in 1st or Reverse. In all reality, if someone is holding the brakes... it doesn't matter what gear you put it in though.
Hmmmm... how long is this sale gonna last?
Old 05-11-2008, 02:43 AM
  #288
Joeyavhu's Avatar
Yea, I normally use one of those gears, but for some reason I choose 5th. Lol.. I dont remember why though.
I would recommend it. Its 125, but it really opened up that power band area a little more.
Ohh yea, and as another side note, even though the new one slid right on, (and I suppose the old one should have slide right off the same way) we had to use a harmonic pulley puller to get the old pulley off, or at least to release it where it was stuck in there good. Lol
Old 05-14-2008, 05:01 PM
  #289
-MD- HHR's Avatar
JBP, According to your website your LSJ crank pulley is listed to fit. "LSJ, LE5, L61, LNF".
This is not true. Yes the pulley will physically bolt onto any ecotec crank, but the LE5 and L61 pulley grooves centerline offset is different than the LSJ and LNF centerline. This in time will eat belts. Also there are other slight differences in the pulleys. I'll post pics later tonight or tomorrow. Most L61 cranks are the same, but there are two diameters. Also the Solstace / Skys are different due to the power steering pump pulley being incorporated into the crank pulley which further move the belts. Also the Outside Diameter of the LSJ is different then the LE5 / L61, and LNF cranks.
Furthermore the 8 bolt LSJ crank spacing is different than the 6 bolt LNF, L61, and LE5 crank spacing.
Old 05-14-2008, 08:18 PM
  #290
116Fanatic's Avatar
Ok, i think this guy might be right...I just had a HECK of a time installing this on my LE5...now that it is installed my crank pulley WOBBLES! Its torqued down! What is going on??? Could this be because of the "Centerline offset"????? Can I get my money back if its not gonna work?
EDIT-MY FAULT!!! I DIDNT LINE UP THE WOODRUFF KEY
Old 05-17-2008, 04:37 AM
  #291
silverfae7's Avatar
I installed the pulley on my 2.4 yesterday with absolutely no problem. Took about 15 minutes. If you measure the LE5 pulley against the JBP one, the offset is exactly the same and so is the diameter. The belt will run on the inner grooves and the outer one will not be used. It fits perfectly on my engine. Great product JBP!!
Old 05-17-2008, 07:20 AM
  #292
ItalianJoe1's Avatar
Wait, the LNF uses a 6-bolt crank? Thats odd...
Old 05-18-2008, 03:49 AM
  #293
116Fanatic's Avatar
I apologize, it was my fault, JBP made a great product
Old 11-10-2009, 10:43 AM
  #294
brutus.nova's Avatar
I hate to bump this post up again but i think i have some information that never got brought up.
about a week ago i was driving to hartford ct for work. I noticed that my cobalt was leaking oil right after i got the low oil light. so I checked over the car and realized there was a decent oil leak... Well thank god for AAA got it towed back to the shop. We pull the shroud off underneath the motor and starting looking for the leak. Thought maybe it was main bearing seal but there was no leak behind the pully... just in front. So we pulled the belt and then the pully (OH BTW THE BOLT WAS ******* HAND TIGHT) and found out that the key way from the crank to the crank pulley had snapped. Looked at the pulley and then saw that the key slot was in a shape of a V. So after about a week of investigating... I talked to a friend of the dealer and she told me about the Crank bolt prolly got reused when the lower end was rebuilt because of the recall on the piston rings. That was 13000 miles ago so it may not show right away but if you reuse that bolt it will come loose and cause this problem. So now because the Stock pulley is on a 3-4 month back order. I am just going to get a JBP pulley if i could just find someone to sell me one in the US.
If anyone can think of something else that could be wrong with this situation that I overlooked please let me know. sorry if you get mad for this forum bump...
Justin
Old 11-10-2009, 10:46 AM
  #295
dear god dont buy from jbp, buy from MRZ they fixed jbp's problem
Old 11-12-2009, 01:38 AM
  #296
87gn06gto07irl's Avatar
after reading this im glad i paid 80 new for mine from a fellow member.
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: LSJ T6061 Aluminum Crankshaft Pulley
