Contacts: JM Auto Racing
Megan Racing Coilovers
Old May 11, 2010 | 01:54 PM
JM Auto Racing's Avatar
Chevy Cobalt SS 06+
JM Auto Racing - View our aftermarket auto parts catalog
Model Number : MR-CDK-CC06
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: Front 6kg/ Rear 6kg
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
MSRP: $1050.00
Old May 23, 2010 | 06:51 PM
bump bump bump
Old May 23, 2010 | 07:38 PM
heathkidder's Avatar
can you post more pics of maybe the back and how low it really goes?
Old May 23, 2010 | 07:43 PM
Will try to get some additional picturews
Old May 23, 2010 | 07:48 PM
ok thanks how low do these actually go ?
Old May 23, 2010 | 09:00 PM
3.5"
Old May 31, 2010 | 08:26 PM
bump bump bump
bump bump bump
Last edited by JM Auto Racing; May 31, 2010 at 08:26 PM. Reason: Automerged Doublepost
Old May 31, 2010 | 08:37 PM
TwiztedSS's Avatar
East Coast Cobalts
I have these on my car and i have never had a problem...
Old Jun 1, 2010 | 08:07 AM
great to hear. THanks for the input!
Old Jun 7, 2010 | 09:20 AM
bump bump bump
Old Jun 13, 2010 | 07:35 PM
megan coilovers now 10%
Old Jun 20, 2010 | 09:35 PM
bump bump bump
Old Jun 27, 2010 | 06:13 PM
bump bump bump
Old Jun 27, 2010 | 06:15 PM
blackss2.0's Avatar
pictures of how low they go
Old Jun 27, 2010 | 06:17 PM
posted. first post.... the go as low as 3 inches
Old Jul 4, 2010 | 09:00 PM
bump bump bump
Old Jul 4, 2010 | 10:02 PM
b00sted06ss's Avatar
still alot of money but you get what you pay for!
Old Jul 4, 2010 | 11:19 PM
THis is true. Megan makes a great set of coilovers
Old Jul 4, 2010 | 11:22 PM
free bump
Old Jul 11, 2010 | 05:00 PM
10% off the listed website prices
Old Jul 18, 2010 | 05:51 PM
bump bump bump
Old Jul 26, 2010 | 10:17 AM
last week of the 10% off sale. Visit Jmautoracing.com and use coupon code JMGO10
Old Jul 30, 2010 | 10:35 PM
coilovers are 899 shipped
Old Jul 31, 2010 | 10:54 AM
ericgt79's Avatar
i found them here for 865 shipped...will you beat that price?
http://www.raceinspired.com/cs-20-coilovers.aspx
Old Jul 31, 2010 | 04:33 PM
They are not 865 shipped. There 869 plus shipping. Here is their estimate: I am saying 899 shipped. There charging 932
