Mid Central NE, KS, IA, MO, and IL
Blower
Old Jul 19, 2009 | 05:10 PM
PikesCobaltSS's Avatar
Blower
Hey I was driving down to gulf shores yesterday and I was doing 80 plus the hole way it took me 9 hrs and Now I think I have blowen my blower up of fked it up has anybody had the same problem or heard of it bc I have to tow it home now
Old Jul 19, 2009 | 05:39 PM
SS SCHGD's Avatar
I haven't had a problem doing 80+ for 9+ hours before, we drove to Florida from IL (and back) in the stage 2 Cobalt. Probably the only time we were under 80 was when stopping to eat/get gas and when getting back up to 80. No problems at all. Hope it get fixed for you.
Old Jul 19, 2009 | 06:53 PM
WickedSS2005's Avatar
well a little more info will help. What is going on? Symptoms?
But the blower is not going to fail like that under the conditions you stated unless is was a faulty unit from the get-go
Old Jul 19, 2009 | 06:54 PM
Old Jul 19, 2009 | 09:03 PM
1bdstlLSJ's Avatar
Im betting you had low oil in the blower already while driving, then you were driving 9 hours straight with the mods you have doing 80+ and no cooling mods and it siezed up on you.......I have seen it happen on a lightning and an 03 Cobra.
Old Jul 19, 2009 | 09:09 PM
G85 SS's Avatar
More info? What happened with the blower?
Old Jul 19, 2009 | 09:12 PM
ShortStack's Avatar
Just saying your car stopped working gives us absolutely nothing when trying to diagnose a problem.. over the internet....
More specific please.
No... Blower is a sealed unit.. it doesnt lose oil...
Last edited by ShortStack; Jul 19, 2009 at 09:12 PM. Reason: Automerged Doublepost
Old Jul 19, 2009 | 09:33 PM
1bdstlLSJ's Avatar
Want to bet?? You think no cooling mods and 80+mph driving for 9 hours straight wont cause a problem...I have seen Eaton blowers burn off oil from heat causing them to sieze. You are supposed to change the s/c oil in the eatons often especially the M62's which make a crap load of heat. Also the bearings should be changed out as well every certain amount of miles....His blower is shot im betting from heat or the bearings crapped out. If you would like we can discuss the Eaton m62 being a so Called "Sealed Unit"....
Old Jul 19, 2009 | 11:27 PM
SS SCHGD's Avatar
at 80 mph or more and cruising, I don't think the blower would be in use (as in no +PSI) no?
Old Jul 19, 2009 | 11:31 PM
boostedss26's Avatar
A blower can use oil eventhough it is a sealed unit
Old Jul 19, 2009 | 11:41 PM
NVMYCOBALTSS's Avatar
Blowers are belt driven and are in use as soon as the car starts. You do not see positive boost pressure because of the bypass valve being open when your foot is on the skinny pedal.
Old Jul 19, 2009 | 11:45 PM
Well, it's sealed. As in it doesn't share oil with anything but itself... so what other definition of sealed is there? There is no need to change the bearings and oil "often". Hell, I have a print out from EATON that says it's "recommended" to change the oil at 100k. I only changed mine because I ported it. The blower will not be making "a crap load of heat" unless it is pressurizing the intake mani. So, at cruise, there is no heat production that would be harmful enough to cause damage that severe
Old Jul 20, 2009 | 04:16 AM
dylaNNN's Avatar
take it to speed and sound and find out whats wrong with it
Old Jul 20, 2009 | 05:53 PM
Ok so we have looked at down here I burned the oil up and the car runs fine it just makes a real bad sounds so i am getting it towed home from here on sat
Old Jul 20, 2009 | 09:17 PM
1bdstlLSJ's Avatar
GL man! It probably needs a new blower....Was compression good etc?
Old Jul 20, 2009 | 11:24 PM
poppagun's Avatar
Bring it by the shop
Old Jul 20, 2009 | 11:34 PM
GreyDog72's Avatar
my blower started to leak oil so i had to replace a seal on mine. did you check to see if your was leaking?
Old Jul 20, 2009 | 11:35 PM
GreyDog72's Avatar
my blower started to leak so i had to replace the seal. did you check yto see if yours was leaking?
Silverbullet333
Oct 4, 2015 02:27 PM
jimbofug007
Oct 2, 2015 12:06 PM
goaliemo
Sep 28, 2015 01:37 PM
yellowsupercharged06
Sep 17, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
