KC area random talk thread
Sweet, I'll take those off your hands for ya...how much do you want for them? Does MKC mount tires and alignments? I want to do it all at once and if you guys do it that would be awesome. If not, I've heard good things about Revline, I'll try calling them tomorrow.
How much do you want for those springs then?
**** I can't post on this forum for ****.
i may not get an 02 wrx wagon for winter. as.....we have no winter here...
trav. i got some videos uploading that should have been seen a long time ago. around the time when i first got my methanol going
Last edited by EXsoccer1921; Jul 30, 2009 at 01:48 AM. Reason: Automerged Doublepost
i'm not gonna be up there for it. i need to find a job so i can spend more money on this car. new fuel system, new trans, new clutch, new wheels(track), new tires(track), new suspension, few msd components, fill the holes in the trunk. all while trying to stay at the track to do some bracket racing
just like going to a test and tune. except a little more expensive to partake. i normally just go to the local track cause i've gotten used to staging there, the tree, and my rollout on the bfg's so i'll hit like .060 and lower lights every pass. which gives me a HUGE advantage cause most of the people in the class i race in come out for ***** and giggles and don't know how to cut a light
you also need to concentrate a lot more. you can't get distracted by anything while you're at the line or it'll throw you outa your groove. keep your eyes off the other guys lights if you're leaving second cause that too will through you off. when you do get up to the tree, do what they call courtesy staging. which means you only trip the first set of lights, then when your opponent lights his/hers, roll in to the second set. theres also a feature called autostart. i don't know if kcir or heartland use it. but once one person trips the second set of lights, you have 7 seconds before the tree counts down. if your second stage lights aren't lit youre disqualified
look for something called street, or something along those lines. and look for an ET break too. (12.50 and slower most of the time). street classes are mainly exactly the same rules as no box, or no/e, classes. except the street classes will only alow a DOT tire. so street tires and DOT drag radials are accepted. no slicks.
Last edited by EXsoccer1921; Jul 30, 2009 at 02:08 AM. Reason: Automerged Doublepost
but got to be leaving for work in a hour
