Avid Trans mount set for Cobalt SS Super/Turbo
Tired of wheel hop, and excessive movement of the motor with your 05+ Cobalt Supercharged, 05+ Cobalt Turbocharged vehicles.
Avid has created the perfect solution! They have created from scratch, billet aluminum transmission mounts to eliminate all wheel hop! These are machined from high grade aluminum, and have a center section made from polyurethane to help eliminate vibrations from the motor.
No modifications are required to install these, they are a perfect factory replacement set that you can reuse your factory bolts with.
Price is $221.99 for the pair.
Item is located in our shopping cart here:
http://www.modernperformance.com/pro...oducts_id=1755
TurboTechRacing
Oct 27, 2015 07:58 AM
