N2MB Racing N2MB Racing is a supporting vendor.
Contacts: phrozen ; jay@n2mb
wotbox installation instructions for ls 2.2
Old Nov 16, 2010 | 11:36 AM
jay@n2mb's Avatar
as per request , i do not have installation pictures but i do have diagrams. if someone can take pics i would be more than happy to merge it with the post
wotbox blue wire
this is your tps input wire
this is the wotbox tps input. the wotbox needs to see around or less than 1v at rest
at wot the wotbox will need to see this go over 3v
Old Nov 16, 2010 | 11:37 AM
jay@n2mb's Avatar
wotbox green wire
the green wire is the clutch pedal input to the wotbox.this wire will be tapped into the wire you see on the diagram
Old Nov 16, 2010 | 12:15 PM
jay@n2mb's Avatar
wotbox yellow wire
this is your rpm input to the wotbox.the will be tapped in
Old Nov 16, 2010 | 12:45 PM
jay@n2mb's Avatar
wotbox red/black wires
the red/black 16 ga. wires are for the ignition cut. you will need to cut the pk/bk wire on the car and connect the red side and black side of the wires as you see in the diagram
Old Nov 16, 2010 | 12:48 PM
jay@n2mb's Avatar
The 18 gauge black wire (not the paired black) needs to be connected to a GOOD chassis ground.
ALL WIRES NEED TO BE SOLDERED!!!
scotch locks or quick connects are not good connections. if you have ever done anything electrical before then you should be familiar with the term mechanically tight,electrically loose.
if you have any other questions feel free to contact us via email at support@n2mb.com
thanks and best regards
jay
Old Nov 17, 2010 | 09:32 AM
BlackCobalt707's Avatar
my blue wire is tapped into the APP sensor. or do i actually tap to the tps or is that the actual tps? also i got a question. when i hit my 2 step and i know im not supposed to do this but its just nice hearin flames, after about 10 seconds my gauges start going haywire. like my power steering pops up on my indicator, my needles stop working, etc. until i pull the battery for a few seconds. any clue wat might cause this? thank
Old Nov 17, 2010 | 10:00 PM
jay@n2mb's Avatar
on a stock ecu im guessing after a while it starts to think wtf is going on..idk.. 10 seconds is a looong time on the two step lol.
ideally on dbw cars the app sensor because its a direct input off of the pedal and not the output to the throttle body from the ecu
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Extremespeed
Sep 29, 2015 04:34 AM
