2007 ss...
Old Apr 3, 2020 | 09:46 PM
fluv11's Avatar
2007 ss...
I have a 07 ss 2.4 na, dyno at 210hp, 12.5:1 compression, built bottom end with domed pistons, built head, ported and milled, comp cams, it's a dirt racer, I have some of the bolt on goodies like header cold air intake, except I still run stock injectors stock fuel rail, stock plug wires, stock ignition, stock 2.4 intake manifold, stock throttle body, ..
My question is, would changing any of those I mentioned get me more power? more torque? quicker? faster? or should I just leave it as is? Always trying to go faster..thank you
Old Apr 6, 2020 | 10:02 AM
Really depends on how much youre willing to spend to gain a few percent in power.
2.4 intake manifold is probably the best stock manifold for any ecotec trying to make power NA.
Adding a larger throttle will help slightly, I think ZZP sells an adapter plate to run an LSJ throttle body on an LE5 intake manifold but youll need a tune.
https://zzperformance.com/products/l...-adapter-plate
Old Apr 6, 2020 | 11:12 AM
jdbaugh1's Avatar
Welcome
Old Apr 6, 2020 | 12:03 PM
fluv11's Avatar
yes, I'm ordering the throttle body and adapter plate, also getting 34# injectors and get it retuned/dynoed, what could I expect in hp from this? 10hp?
Old Apr 6, 2020 | 12:05 PM
I would say 10 at the most
Old Apr 6, 2020 | 01:01 PM
ProfDNS's Avatar
You're pretty much at max after the TB + plate. You could do the short tube + catless for your specific application (again, tune is needed) but you'd only net gain maybe about 15-20HP for spending $1000. After that, it's forced induction to go any faster. Slowbalt here knows his **** for the 2.2/2.4L since he's done it and more himself.
...just don't ask him if the car has left the blocks yet
Old Apr 6, 2020 | 03:51 PM
LOL, Im busy working on my rwd 2.4 car
RDKDESIGNSG5
Dec 30, 2009 08:28 PM
rizzer1
Aug 28, 2009 01:51 AM
Projekt
Mar 18, 2008 04:47 PM
rcmpayne
Jul 25, 2006 07:54 PM
