Hi from Philly
Old 06-13-2018, 01:00 PM
Hotlineelec's Avatar
Hi from Philly
Here in philly with constant problems with my ss!!
Old 06-13-2018, 01:04 PM
Welcome! What problems do you have?
Old 06-13-2018, 01:06 PM
Kolt's Avatar
Welcome, post some pics and lets get her figured out.
Old 06-13-2018, 01:32 PM
jdbaugh1's Avatar
Craigslist buy? Welcome
Old 06-13-2018, 05:17 PM
Omg this car has been a nightmare
I appreciate all the hellos!! I have an 09 had it since new has been garage kept and was a “play car”. Times have changed and now it’s my daily driver. I have installed a zzp dp k&n intake and had zzp flash my ecm after having the gm 1 installed.
the car ran like a raped date for a few months then I blew out the stock intercooler. Had a few codes of course but they were turbo related cause of a major leak. Thru some insurance juggling I had a buddy install what I thought was going to be a zzp ic with the new pipes which he didn’t do so now I’m stuck with a ic that doesn’t really match the car and a ton of codes. P0013 the exhaust actuator
P0236 turbo boost sensor
P0106 MAF sensor
Of course I called zzp for guidance and they are no help what so ever they tell me to bring the car in 🤤 yea ok!! So I’ve checked for boost leaks none. I’ve cleaned the maf, nothing there and replaced both actuators and nothing. The car always drives weird intermittent boost with a choo,choo,choo noise after I let off. Surging in fifth gear. No power sometimes where I damn near have to floor it in first to move. I don’t know what else to do guys I can’t afford another car so gotta fix this one please help!!! I buy lunch for whom ever can figure this one out!!! Thanks!!!
Old 06-13-2018, 05:28 PM
Forgot
i forgot to add too the P0236 doesn’t always come up. If I reset the codes immediately the P0013 code comes up then the P0106 code comes maybe a day or two later which is strange cause the turbo does all this weird stuff and the first code is the exhaust actuator code!! Please help me!!!
Old 06-13-2018, 05:42 PM
Boost leak test first. How does this intercooler setup your friend did look?
Old 06-13-2018, 09:06 PM
2nd this.
Old 06-14-2018, 12:17 PM
It’s a jdm intercooler. It has two reducing elbows where the pipes attach to. There are no leaks I boost leak tested it up to 27 lbs and all holds good. The jdm ic was installed somewhat professional. He welded brackets and everything I just don’t like the reducers cause he had to cut the hot and cold side pipes to get everything to fit but everything is tight and leak proof
Old 06-14-2018, 01:19 PM
Slobodan Milošević
07blackg5's Avatar
Innnnnnnnnnnnnn
west Philadelphia, born and raised...
Welcome
LnfMikey
06-12-2019 06:57 PM
Dustin Mitchell
02-22-2019 07:24 PM
08Fosgate_balt
07-04-2018 02:47 PM
JonyyB
Next Level Autosports
13
02-17-2007 07:28 PM
JonyyB
SMG Autosports
12
01-06-2007 06:12 AM
Quick Reply: Hi from Philly
