I need some help with my 06 ss that won’t start
Old Nov 20, 2021 | 02:11 PM
r_erik270's Avatar
I recently had the radiator installed after my old one cracked but soon after that my car wouldn’t start. Idk if it’s because of the battery, starter, alternator, or fuel pump. When I go to start the car there’s no crank however all the lights do turn on. Coolant is leaking from right here idk what part is that and/or if it’s the reason it won’t start.
Old Nov 22, 2021 | 10:20 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Coolant isn't leaking from there, as that part does not have coolant flowing through it. You leak is most likely higher up on the water pump.
Sounds like a dead battery, dead starter, or someone removed some parts during the install and forgot to reconnect them, or reconnected them to the incorrect points.
Old Dec 21, 2021 | 07:23 PM
Smc252's Avatar
100% right. Check those things, it helps to use a good flashlight!
cheddar670
Sep 6, 2021 12:50 AM
codygoofy
May 14, 2010 12:47 AM
usdm08
Aug 4, 2009 05:54 PM
gos2difbeat
May 19, 2009 01:48 PM
SS-=MKR=-SS
Dec 22, 2006 03:40 PM
