Whats up
Old May 22, 2019 | 12:55 AM
LnfMikey's Avatar
Whats up
Whats up, ive had a cobalt ss for about 6 years, first time joining a forum.
Old May 22, 2019 | 06:22 AM
63 Nova SS's Avatar
Welcome
Old May 22, 2019 | 08:29 AM
jdbaugh1's Avatar
welcome
Old May 22, 2019 | 09:29 AM
Kolt's Avatar
Welcome, post some pics. What all do you have done
Old May 22, 2019 | 09:59 AM
LnfMikey's Avatar
Actually right now im in the middle of the ldk and f40 swap. First time doing any engine or transmission swap for me. Kind of scary.
Old May 22, 2019 | 10:05 AM
steelmesh's Avatar
Sup!
Old May 22, 2019 | 10:09 AM
LnfMikey's Avatar
Hows it going!
Old May 22, 2019 | 11:40 AM
michael23v's Avatar
Welcome
Old May 22, 2019 | 11:41 AM
Welcome to the party.
Old May 22, 2019 | 04:57 PM
LnfMikey's Avatar
Im trying to remove the subframe. I got 3 bolts loose and ready to come off but the rear passenger one holding the control arm is just spinning. Anybody ever deal with this?
Old May 23, 2019 | 07:01 AM
royce777's Avatar
its prob seized to the control arm center sleeve. Try some Kroil. then a impact gun.
Old May 23, 2019 | 10:37 AM
LnfMikey's Avatar
Will it come out even if the cage nut on top is spinning? The cage broke. Im thinking of using a sawzall later.
Old May 23, 2019 | 11:10 AM
royce777's Avatar
I never had the issue with the cage nut but it is VERY common. Someone else can chime in.
Old May 23, 2019 | 11:11 AM
royce777's Avatar
I have some good condition cradle bolts if you need them.
Old May 23, 2019 | 03:30 PM
LnfMikey's Avatar
I havent checked, but if i cant find them at the dealer il message you about the bolts because i probably will need new ones. Any idea if the cage nut can be bought? I only see part numbers for the bolts.
Old May 23, 2019 | 03:34 PM
exninja's Avatar
Powell wrote up a how-to for this. I'll see if i can find it real quick.
Old May 23, 2019 | 03:42 PM
exninja's Avatar
https://www.cobaltss.net/forums/susp...shings-301627/
Old May 24, 2019 | 08:22 PM
LnfMikey's Avatar
Thanks for that, it gave me a way better idea of what i was dealing with. Finally got the subframe with engine and transmission out
Old May 24, 2019 | 08:28 PM
LnfMikey's Avatar
Old May 24, 2019 | 11:43 PM
AfterShok's Avatar
Welcome and good luck with your progress
Old May 31, 2019 | 05:58 PM
TurboTechRacing's Avatar
Welcome! Be sure to checkout www.TurboTechRacing.com
Old Jun 5, 2019 | 03:08 PM
LnfMikey's Avatar
I have been taking my time on the ldk swap. I found these cracks on the exhaust mainfold and turbo where they connect. I cleaned it with a dremel to take a better look. Is this something that should be fixed? Theres no cracks on the outside.
Old Jun 5, 2019 | 03:17 PM
Cracks are totally normal for the stock turbo/manifold. Every one Ive ever seen from an LNF is like that. There is no issue with using it as it is.
Old Jun 5, 2019 | 03:31 PM
LnfMikey's Avatar
Oh okay nice. Thank you! I was starting to worry.
Old Jun 5, 2019 | 05:32 PM
Yup that's normal. Welcome!
