It all finally arrived!!!!!!
waitin on my court date thurs to see what happens. if i got the money im buy the tools and some other things like wire loom, connectors and stuff like that. i dont want to be running down the street when my car is tore apart... i need to get the key for the shop and do that on a sun or something... you down for coming up there with me if i get that ok'ed?
good possibility we are guna be workin on my car at the shop a week from tommorrow at the shop of you want to swing by and check it out. if we get it done ima fill the bottle and go straight to the track hahaha
so next saturday? yea sounds good, im not sure what i work yet but i think im going to be off that day. what time exactly? and i need to get my tran inserts installed...
update. ive talked to a guy that i work with and we will be openin up the shop on this up coming sunday and gettin as much done as we can. ive gone over all the instructions and the only things i am a little conserned about is the wiring of the tps/WOT window switch and the acctual mounting of the fuel and nitrous solinoids. im thinking of putting them underneath the wiper cowl if there is enough room. any ideas on where to put them? i want it to be as clean an install as possible. everything will be zip tied and wire loomed. im just trying to get everything figured out in my head before i get into the install and have to figrue it all out then. any ideas will help!
another update guys
i have almost completed the install. all i have left to install is the main nitrous line and the purge solenoid and wire up the main nitrous switch. and the tps/rpm window switch. the lines are all run under the seat and all wires are hidden, the bottle is mounted and the warmer and remote opener work great. i mounted the nitrous and fuel solenoids on the core support up under the plastic cover that conects to the grill. the only thing that can be seen when opening the hood is the one fuel line coming out of the fuel rail. i plan on taking car of that later.... my switches are mounted on the center consol right behind the little change holder. my purge button will be mounted somewhere else where it will be easier to access when i want... other than that im almost done. im pumped and really wanting to get it done. but i will have to wait and it blows. as soon as i get it all wire loomed and buttoned up i will post pics and let the critics of this site tear me apart about what all i did wrong hahaha(i hope not tho
) but for now i have to go and find a dp to complete my bolt on list for the balt. later guys
i think we need to clarify that you and your girlfriend had the drunk sex. hahaha just watch out for anymore of those tiolet seats, i hear if you hit em with your head you get a massive knot on your forehead....
be careful with that. I was advised by the place that is doing my nitrouse not to go over 50 shot without replacing head gaskets and studs first. And just to be extra safe i only went with the 35 shot for now. I should have my ZEX kit on and ready for me to get my car tomarrow just intime for the show/race im going to on saturday. It cost me $1650 after install and tax. I got the 10lb bottle, Bottle Heater, Red LED purge Kit, Pressure Gauge, Window Switch, and the release that lets the nitro outside of the car if the pressure gets to high. And im running the NGK Laser Iridium plugs 1 stage cooler as needed.
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
