Nitrous Oxide N20
Diffrences in the MSD Window Switch and the Zex Window Switch??????
Old Feb 13, 2007 | 08:27 PM
06Pursuit's Avatar
I was just wondering if there were any major diffrence between the 2. I was planning on getting a nitrous kit but hit a wall when considering a window switch. Any info on ease of instalation would be helpful!!!
Old Feb 13, 2007 | 08:35 PM
thebonds's Avatar
I just finished putting in my msd switch yesterday. It's pretty easy if you do it when your not hung over and still partly drunk. I'm pretty sure that was my only problem. Don't know much about the zex kit. To make things the easiest for you, I'd stick with all one brand. If you get a zex nitrous kit, get a zet window switch. Instructions seem to flow a little bit better togethor is all.
Old Feb 14, 2007 | 06:21 AM
06Pursuit's Avatar
so basicly, they both perform the same function?
Old Feb 14, 2007 | 09:07 AM
IonNinja's Avatar
the only major difference between the two is that the Zex unit allows you to turn off the nitrous for however many gears you choose.
so if you don't want it to spray at all in first gear due to traction issues you can set it up that way...the MSD does not have that.
also if you have a Zex kit, the Zex window switch is easier to hook up because it doesn't need a relay.
in general though, they do the same damn thing...
Old Feb 14, 2007 | 03:50 PM
06Pursuit's Avatar
nice thx for the info guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
dieGone
Sep 23, 2015 10:20 AM
TylerJHowell
Sep 21, 2015 06:47 PM
