Nitrous Oxide N20
gauge question
Old 12-28-2009, 02:31 PM
Pittsburghcobalt's Avatar
gauge question
got zex nitrous kit. I hear you can use an air fuel ratio gauge to determine if your running to rich to lean. Can i install a air fuel ratio gauge for nitrous?
Old 12-28-2009, 02:35 PM
myfakeevo's Avatar
all nitrous is a nitrogen hydrogen. you cant run pure oxygen in a motor so its mixed. as long as you run more fuel with more oxygen, the car will never blow up.
run colder plugs and bigger injectors and you basically will never have to worry about blowing your motor.
the thing is, by the time your gauge tells you that your running lean, you might have already done damage to the piston rings.
So i think running more fuel would be more of a safer idea then just a wideband alone
Old 01-08-2010, 05:25 AM
harryresh's Avatar
imagine that, an AFR gauge will tell you the AFR!
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
ineedacobaltss
11-07-2015 02:25 PM
brandon04
10-21-2015 07:04 AM
09-27-2015 08:53 PM
Quick Reply: gauge question
