Nitrous Oxide N20
GM STAGE 3 nitrous jet size?
Old Mar 27, 2011 | 07:38 PM
RAY321's Avatar
I have installed the GM stage 3 kit with nitrous, everything is working great.
My question is what size jet are you guys running, I have a .036 that is running a little rich around 10.1 AFR
Old Mar 27, 2011 | 07:50 PM
ebristol's Avatar
That really depends on your nitrous setup. Are you using a bottle warmer?
Old Mar 27, 2011 | 07:55 PM
RAY321's Avatar
yes I am using a bottle warmer set at 950 deg's
Old Mar 29, 2011 | 09:53 PM
batboy's Avatar
Gawd, I hope you're not setting it at 950 degrees. Perhaps 950 psi?
Old Mar 29, 2011 | 10:37 PM
BIG SS TC's Avatar
it should be right their or 1100 psi that where i had mine set in my V6 stang and it worked perfect cuz when u use the bottle it cools down so i always had it sed a little hight so i would be ready to use again. what brand are u using????
and u can always buy a few Jets in either direction for the fuel and nirtous.
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
