Nitrous Oxide N20
hookup for rpm
Old Oct 21, 2007 | 12:36 AM
silentd's Avatar
hookup for rpm
i have the msd rpm window switch and i dont know where the one wire goes to monitor the tach, or rpm... help please
07 ss/sc
bump anyone??
Old Oct 21, 2007 | 02:04 AM
IonNinja's Avatar
search in the how-to section for shift light installs...I know in those threads they note which wire to tap for RPM.
Old Oct 21, 2007 | 04:11 AM
silentd's Avatar
they show just to get a reading. i need the negative and positve terminals on the coil pack... i think its the red and the black one and not the middle ones...
Old Oct 21, 2007 | 04:35 AM
ItalianJoe1's Avatar
You should be able to use the signal wire and a common ground right? I'm not sure about the MSD one, but thats how most window switches work.
Old Oct 21, 2007 | 05:01 PM
IonNinja's Avatar
the only wires that you need to tap your car for with the MSD switch is the tach signal and the throttle position sensor so not sure what you are looking for...
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
roadrunner132
Sep 19, 2015 04:35 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
