install question
install question
where has everyone but their nozzle. when you screw into the fuel rail do you have to do anything to make the fuel flow? what wire did you tap into for you're window switch (rpm wire). where did you run the nitrous line outside of the car?
lol ok first things first you need a schader valve wrench. its like two dollars at autozone. if they dont know what it is, its the same kind of wrench you need to take the valve out of a tire. my nozzle is before the supercharger bout 6" hope that helps a bit
