Nitrous Oxide N20
knocking on n20....
Old Sep 11, 2009 | 04:34 PM
  #176
damien's Avatar
You could always test the solenoids with the car off but the system activated, I'd just be careful to not burn them out. Just hit the button a few times for no more than 3 seconds per click, you'll definitely hear it spray if its working properly.
Old Sep 11, 2009 | 04:37 PM
  #177
ChriSS/SC's Avatar
Yeah I'm gonna try that.. Suppose the solenoid is "stuck".. How do I fix that?
Old Sep 11, 2009 | 05:04 PM
  #178
fjordbosun's Avatar
It ca be disassembled and serviced, keep track of the order of parts as they come out of the body. They are really very simple.
Hey Chris here is a link, most solenoids are close to the same basic forrm
http://www.mpsracing.com/Instruction...id_Rebuild.pdf
Last edited by fjordbosun; Sep 11, 2009 at 05:04 PM. Reason: Automerged Doublepost
Old Sep 11, 2009 | 08:11 PM
  #179
RA122324's Avatar
Fixed or no?
Old Sep 11, 2009 | 09:40 PM
  #180
StreetLC's Avatar
He just needs more nitrous IMO, 150 shot!!!!!!
Old Sep 11, 2009 | 10:25 PM
  #181
fwdGTP's Avatar
if anyone's seen the My New Honda video, it was basically like that but worse lol, the camaro got sideways through 2nd from a 50 roll, then hit 3rd and pulled like 5 cars instantly lol. and we were like where's my goddamn nos. i might post the video on photobucket tonight or something, cause it's too embarassing to put on youtube...
Old Sep 11, 2009 | 10:27 PM
  #182
drew1991sf's Avatar
how bad did u get raped by the camaro?
he has 403whp/378wtq and ran 11.99@116
LMFAO
Old Sep 12, 2009 | 02:48 PM
  #183
ChriSS/SC's Avatar
lol. What do you expect with a cobalt that ran slower than stock knocking and running straight fuel with no nitrous against an 11 sec camaro hah.
fjord... Thanks man I'm gonna troubleshoot it in a few minutes.. Then gonna check the wiring and what not
Old Sep 12, 2009 | 02:55 PM
  #184
drew1991sf's Avatar
and he doesnt just have heads/cam. ik the guy he has a 454 in it LMFAO
Old Sep 12, 2009 | 09:03 PM
  #185
ChriSS/SC's Avatar
He kept trying to run me again like it was even worth it...
****** slower than stock POS cobalt not working right vs. mr. fishtail on the freeway haha
Old Sep 12, 2009 | 09:11 PM
  #186
drew1991sf's Avatar
the numbers i post was on his stock motor. but right now im pretty sure its high 400s
  #187
ChriSS/SC's Avatar
Prolly like high 900s
Old Sep 12, 2009 | 09:13 PM
  #188
drew1991sf's Avatar
lol but that is high 400s on stock intake manifold when he changes that and rear end he expects mid 500s atleast lmao
Old Sep 12, 2009 | 09:21 PM
  #189
N01SS's Avatar
Just remembered i was registered here, its not so much that i was tryin to run you again man i just wanted a reason to go cause the other guy wanted a ride. And i wanted you to see if you could figure your issue out.
But anyways, no one told me you were spraying, so had i been a bolt on car....i coulda been in some trouble, once you get that sorted out you'll be in good shape.
And i appreciate the fact that you stepped up and wanted to run...no one else did. fun times.
Hope you get the juice figured out soon, nice car
Also, if you guys could post the video...or just PM it to me, that'd be sick....i'm not gonna go around posting like i'm all billy badass or anything, i'd just like to see it.
thanks
Old Sep 12, 2009 | 09:32 PM
  #190
ChriSS/SC's Avatar
Originally Posted by N01SS
Just remembered i was registered here, its not so much that i was tryin to run you again man i just wanted a reason to go cause the other guy wanted a ride. And i wanted you to see if you could figure your issue figured out.
thanks
I just straight up knew something was way off.. Car ran slower than stock.. running fat in the 9afr range.. And somehow knocking 10 degrees on spray.. But I didn't want to make ricer excuses so I just told you straight up your car is faster and there's no point in running again because it's still messed up after troubleshooting it all day today..
I'm pissed that it's not working because i had a CLEAN spray run 2 hours before we ran... And never ran it in between that and our run.. I was ready to go and it was pulling harddd.. And it suddenly FAILED baddd and I can't figure it out
I don't care about losing if we're just doing a friendly run.. And I heard that you were the only one there who was down to run.. So I figured I'd test my shot out.. And of course it doesnt work when I most definitely need it to
w/e though. I will let you know when I am actually running right and although you will still **** on my life.. I will run you to show that I'm not some honda civic
Old Sep 12, 2009 | 09:50 PM
  #191
N01SS's Avatar
It was all in fun......and **** hondas
just worry about your car, get the spray sorted out, and get it running good. If you wanna run for fun again afterwards, i'm cool with that...but i don't wanna see you blow your car up so take your time and get it right!
Send me the video
Old Sep 12, 2009 | 10:02 PM
  #192
ChriSS/SC's Avatar
Alright. Good stuff man. I'll tell my buddy to send the video.
Old Sep 12, 2009 | 10:24 PM
  #193
fwdGTP's Avatar
ill put the video up when i get a chance.
Old Sep 12, 2009 | 10:31 PM
  #194
drew1991sf's Avatar
good *****
Old Sep 13, 2009 | 12:36 AM
  #195
fwdGTP's Avatar
Originally Posted by drew1991sf
good *****
STFU ***, your car tuned yet? probably wasnt worth 500 dollars...
Old Sep 13, 2009 | 12:40 AM
  #196
drew1991sf's Avatar
yup tuned :]
gained 9whp with the car being heat soaked after 8 dyno pulls and over the baseline the day before when it was 10* cooler.
going back to do an actual power pull next month when its cooler outside since they said i wasnt able to put down good numbers since it was 100* in the dyno room
Old Sep 13, 2009 | 12:46 AM
  #197
fwdGTP's Avatar
that sucks, does it idle good with the 60s?
Old Sep 13, 2009 | 12:52 AM
  #198
drew1991sf's Avatar
idk its kind of rough after u come to a stop at a light for like a few seconds but its w/e.
Old Sep 13, 2009 | 12:54 AM
  #199
ChriSS/SC's Avatar
Drew you're the man.
Anyway.. Troubleshooting time yet again! Wish me luck.
Old Sep 13, 2009 | 12:58 AM
  #200
BLAZIN07SS's Avatar
I'm too JDM for you
raise the idle a little
this is why i had my F&F style kit. simple and it never failed. lol
Last edited by BLAZIN07SS; Sep 13, 2009 at 12:58 AM. Reason: Automerged Doublepost
