Nitrous Oxide N20
MSD Window Switch Help
Old Jun 19, 2008 | 05:41 PM
07cobaltguy's Avatar
I need some help wiring in my MSD Window switch. The wiring isnt making sense to me.
Red= Power (obviously)
Black= Ground (again)
White=tach signal (got that taken care of)
_____________________________________ Heres the confusing part:
Gray= Normally closed, This wire will remove the ground source at your desired On rpm, and complete the ground circuit at the set Off rpm.
Yellow= Normally open, will provide a ground source at your desired On rpm, and remove the ground at the set off rpm
so what the hell am i wiring these to. im trying to figure it out but the wording is tricky.
Old Jun 19, 2008 | 05:45 PM
Z Speed's Avatar
only way to test it is get the whole system hooked up and touch the wire to see which one acitvates the system... if its anything like my meth injection kit your going to hook it up to normally open... one basically is telling to to acitvate below the set rpm and the other will tell it to activate above the set rpm
Old Jun 19, 2008 | 05:48 PM
oh ok, but im using the ground wire off the nitrous solenoid?
and its one or the other not both?
Last edited by 07cobaltguy; Jun 19, 2008 at 05:48 PM. Reason: Automerged Doublepost
Old Jun 20, 2008 | 08:52 AM
Z Speed's Avatar
no 100% sure and correct its one or the other. Ive never hooked up a nitrous system so unless I have it in front of me im not sure which wire would work... depends on the wires for the msd if they complete a circuit once triggered or grounded
Old Jun 21, 2008 | 12:34 AM
IonNinja's Avatar
you should PM slowion2 on here, hes got the MSD window switch on his setup
I had the MSD switch when I first got my Zex kit but burnt the bitch up trying to install it
I'm almost positive that the gray wire is not used at all and the yellow wire is actually what completes the circuit to activate the silenoids.
Old Jun 28, 2008 | 06:09 PM
Spanky's Monkey's Avatar
you got the wire diargam on youre coil on plug? trying to wire my buddys msd window switch and i'm not sure of the wiring on the plug cause my car runs on the pack not the cop.
Old Jul 8, 2008 | 09:51 AM
Filapoosis's Avatar
For your nitrous setup, you want to connect the yellow wire to your system. The system completes the circuit at the desired "window".
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
dieGone
Sep 23, 2015 10:20 AM
TylerJHowell
Sep 21, 2015 06:47 PM
