NOS on the 2.0L S/C
I am unsure if NOS has made a kit, but I'm sure someone has info about a nitro kit for the 2.0. Could always try ZEX or NX if NOS doesn't have a premade kit. Also, can try doing one on your own, but I think nitrous oxide systems are retarded unless you plan on using it for drag racing only (and I also mean the car for drag only as it is 100% illegal on a road car.)
Well i know all that but.... i was just wondering how would u hook it it becasue u cant put the Nos.. befor the supercharger.. ud have to drill holes in the manifold????? thats what im ?ing
What would be a safe shot you think to run at i was think 35 maybe a 50
I won't exceed over 100 and I won't try to go above 50 either.
On the LSJ I think you can safely run a 75 shot but it's slightly more built for abuse out of the box then the L62.
Remember, no shot is a safe shot but test and works is at least a 50.
Originally Posted by sneaky
On a 2.2L would be a 50 shot to be safe.
Have you ever sprayed before ? If so, you dont know what the hell your talking about, as long as you have enough fuel to accomadte the extra incoming air, your **** will not blow up. If you get that right, theres next to no way to **** your **** up unless your always on it, or if someone hooked up your **** wrong. Im so tired of people who have never sprayed talk about it like its a bad thing and it will blow your motor.
Originally Posted by mtwal16
dont spray too much cuz ull def blow your motor out and havta buy a new one...ive never sprayed b4 but i have seen it on "The Fast and the Furious", so i know what im talking about.
Im not trying to insult anyones intelligence but i have first experience, and never had any single problems...gone through so many bottles it aint funny. i dunno how yall think ***** gona blow up, but yet when you install a turbo it wont blow up either huh ?
Well i have talked to so experts about putting NOS on my car. They said what most people dont understand is that when you spray a wet kit in a Forced Induction car, it duoble yours shot. Because yes it does go through your supercharger. You still have to drill a hole in your intake, and it sprays just like normal. So if your shot is going to double, i wouls spray a 25 shot. I have the GM Build Book, and if you read it, it tells you that the stock internals for our cars can will stand a 75 shot. So i would go with a 25 at first to be safe. And make sure it is trottle act. This is what ive been told from experts that i have talked to face to face about my car. Hope this helps. ( ZEX makes the best kits IMO)
I used a ZEX kit with my Alero and had no problems with anything until my FPR popped off in the middle of me spraying and I blew my motor to peices... make sure everything is connected firmly.
Spray is bad if it's not setup for the the intended purpose it was made for, track use.
I've watched and witnessed several accidents of street racing when someone activated N20 on the car doing about 70 and ran right into the side of the car that had the right away. I don't condone it's use on the street and I've done test and tuned several cars to run off of ZEX. The application should go by displacement not by how much fuel YOU think it can throw at it. That's just part of it.
Originally Posted by 05YELLOWSS
i run 75 on the track...
how bout some pics of you r setup?
did you have a plate fabricated? if so where. What kit are you usinf. please enlighten us obie one
so you know you **** wont blow up and ****
I know the GM performance handbook says that the car can handle a 75 shot stock. I personally wouldn't touch anything above 55, just to stay safe.
I'm not 100% positive, but I believe they recommended a wet kit through Nitrous Express.
Wet kits like those (Zex carries one too) install into your intake manifold. There is no harm in doing this. Just....don't be stupid or get carried away.
And for the love of God, it is called nitrous, or n2o, or 'the bottle' or 'laughing gas' but NOS is a name brand, and is NOT the correct term for the stuff.
That's like calling any car on the road a chevy, or every tire a Michelin. It's not ok.
88DT
88DT
88DT
88DT
This is sorta off topic but people call circular saws "skil saw", lockable pliers "Vice-grips", adjustable pliars "channel locks", i could name several others, but you have a good point in that NOS is a name brand.
Originally Posted by Bandit2941
If thats the case then why don't you just go put a 300 shot on it?
I've used it on several applications thank you. There is tolerances to be meet and don't insult other users. It just makes you look like a ****. You can have all the fuel in the world but if the motor wasn't designed to take abuse then why bother? Have you ever tore apart a car after (3) 50-75 shots were sprayed in a month before? I have, it's not pretty what it does to small displacement motors. There not meant to handle all those extremes. I think you watched too much F& The F.
I've watched and witnessed several accidents of street racing when someone activated N20 on the car doing about 70 and ran right into the side of the car that had the right away. I don't condone it's use on the street and I've done test and tuned several cars to run off of ZEX. The application should go by displacement not by how much fuel YOU think it can throw at it. That's just part of it. Sounds like you need to go back to watching videos...
A pretty helpful write up on nitrous...http://focusfanatics.com/forum/showt...threadid=11534
