Nitrous Oxide N20
NOS hookup in 2.0
Old Nov 11, 2007 | 11:42 PM
streetrcer909's Avatar
Exclamation NOS hookup in 2.0
hey i am interested in doing a nos kit in the ss/sc wat are the minimum mods required or recomended to run a kit and what kind of power gains can i expect i am new to the whole nos thing and am not too familiar with the different kits and what i would need to run a kit in the ss/sc any help would be appreciated thanks
Old Nov 12, 2007 | 10:58 AM
Old Nov 12, 2007 | 01:01 PM
Sharkey's Avatar
may want to look at the stage 3 kit, it has an alternate tune in it to run a dry 50 shot. when you arm the nitrous itll go to a different calibration, it also shuts the nitrous off 500rpm before your rev limit. the downside to stage 3 is that its technicaly not for highway use, gm voids your warrenty, and it disables your a/c (to discourage using it on a street car)
Old Nov 12, 2007 | 01:16 PM
CTCOBALTSSS's Avatar
Listen to Sharkey. It is a good way to spray. I run the stage 3 pcm in my car. The nitrous gets hooked up in the spring. This is the only way I would spray. The PCM will shut the nitrous off if it detects any errors. It also has a 100 octane tune if you just want to run race gas. For daily driving it has been very good to me.
Old Nov 12, 2007 | 01:53 PM
SSdan's Avatar
CTCOBALTSSS, did you have to provide your vin?
What was required to install the PCM? Did you simply unplug and swap?
Old Nov 12, 2007 | 06:24 PM
did the dealer install stage 3 and how is it as ur dd any problems with nitrous yet?
Old Nov 13, 2007 | 10:21 PM
skymynx's Avatar
he isnt spraying yet. read his post man lol. im sprayin on a 2.7 inch pully no problems. ill be giving CT a hand in the spring when hes ready to hook up the nitrous system.
Old Nov 13, 2007 | 10:36 PM
fballman1987's Avatar
wait are you the one that got the speeding ticket a while back???
Old Nov 13, 2007 | 11:22 PM
cashstacker's Avatar
someone should post up pics of their nitrous install
Old Nov 14, 2007 | 01:10 AM
ya got the speeding tickets and lost my license cuz im under 20. all i wanna do to ss/sc is stage 2 2.9 pulley exhaust header 50 shot of nos and a good tune then start doing traction mods
Old Nov 14, 2007 | 08:43 AM
I bought the PCM off a member. I just installed it and that's it.
It had to learn everything again such as oil life, mpg, avg speed, things like that.
I just unpluged the old one and pluged in the new one. That was it. 10 minutes.
I will be spraying in the spring. I'll do a full write up on how the nitrous works on stage 3, a little video of arming it, purging it, a couple dyno runs, going into 100 octane mode. I'll let everyone know how it works in the spring after the dyno day in May.
And thank you so much for that. I can't wait.
It's good to hear your 2.7 with spray is going well.
Old Nov 14, 2007 | 08:48 AM
thwick's Avatar
just thought of a question, if you can switch back and forth between the stage 3 PCM and the stage 2 PCM, will it reset your oil life and such? because that would be a pain.
Old Nov 14, 2007 | 08:54 AM
Yes it would. That's why i'm just going to run the stage 3 pcm all the time.
It daily drives just like the other one and my AFR is better.
You are right though the oil life would be off. You would have to keep track of it yourself with a window sticker or something.
Old Nov 14, 2007 | 09:00 AM
thwick's Avatar
thanks, good to know before i buy the setup, i'll hopefully be getting the stage 3 kit and a 50 shot setup installed in the spring!
Old Nov 14, 2007 | 09:03 AM
Good stuff man. It's a good setup. Zinner put down 292whp with that setup.
Old Nov 14, 2007 | 09:05 AM
thwick's Avatar
292whp would be great! what other mods were included in that? as of now i'm on the stage 2 with GMPP sport exhaust, and Fujita CAI. Once i put in the stage 3 and nos, it'll be all traction mods from there.
Old Nov 14, 2007 | 09:16 AM
Here is the link to the thread. A header back exhaust system is a must.
https://www.cobaltss.net/forums/show...e+dyno+nitrous
He has the following:
2.8 Pulley
42# injectors
HPtuners (soft tune)
50 shot of nitrous 3500-6800 RPMS
Header-back exhaust
Old Nov 14, 2007 | 09:38 AM
thwick's Avatar
2.8 Pulley
42# injectors
Header-back exhaust
If i already have the GMPP sport exhaust, what would i need? header and downpipe? or is there more?
Old Nov 14, 2007 | 10:18 PM
Just a header and a downpipe. I have the same cat back as you btw.
Old Nov 15, 2007 | 12:46 PM
thwick's Avatar
ok, thanks for the info, much appreciated.
i cant wait to get this all put on in the spring and hit the dyno. i'll be over 300whp soon enough!
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
TylerJHowell
Sep 21, 2015 06:47 PM
