Nitrous Oxide N20
pistons with nitrous
Old Oct 12, 2010 | 12:49 PM
football462010's Avatar
is it better to run a low compression piston with nitrous or high compression.
i plan on boosting it after i get it built but maybe not for a while so i was thinking about running nitrous until i get a turbo on it.
Old Oct 13, 2010 | 02:55 PM
slowbalt84's Avatar
well higher compression and nitrous is going give you a lot of cylinder pressure so i will say lower compression pistons will be better. Same as if you plan on running more boost.
Old Oct 13, 2010 | 03:28 PM
i was thinking that but wanted to make sure low compression wouldnt hinder the effects of those power adders.
also would i be able to run a bigger shot of nitrous with lower compression pistons and not damage anything?
Old Oct 13, 2010 | 04:45 PM
blackvette101's Avatar
assuming your compression ratio is not that high (>11to1) then its not neccassary to run low compression (<9to1) unless your exceeding 50 hp per cylinder of nitrous however with methanol or race gas you can run more than that per cylinder on high compression. but if you plan on boosting it later you might as well lower the compression now.
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
TylerJHowell
Sep 21, 2015 06:47 PM
