Nitrous Oxide N20
View Poll Results: Spray before or after the blower?
Preblower
41
87.23%
Postblower
12.77%
Voters: 47. You may not vote on this poll
Preblower or PostBlower Spray
Old Nov 28, 2007 | 12:26 AM
skymynx's Avatar
Originally Posted by firestorm
great, now i wont feel guilty about augering holes in my JBP intake tube.
I shoulda had it plated, so it at least looked worthless and expensive.
So will stock internalls hold a 75 dry shot pre blower?
bad idea for a dry 75 shot. like joe said ur gonna need one hell of a tune. wet is alot better overall in my opinion and alot safer
Old Nov 28, 2007 | 01:02 AM
firestorm's Avatar
joe says nos, im still looking for opinions on brand as well.....
Old Nov 28, 2007 | 07:21 AM
skymynx's Avatar
I say NOS as well. got basically the same setup as joe
Old Nov 28, 2007 | 11:30 AM
ItalianJoe1's Avatar
The kit itself doesn't really matter. Any kit is ok, just make sure that its complete and use a quality window swtich if you are gonna use one. Have some sort of WOT switch, either electrical (TPS) or mechanical (behind pedal) don't be like me and just use a hand-held trigger button, and an arming switch for the power to the whole system. That makes it as safe as possible, as you have to open the bottle, arm the system, be at WOT and between the right RPMs before it sprays. NOS makes a great switch for it, I think its a 14950NOS part # but I'm not sure. Thats what I used on dad's truck and its perfect, easy to wire, small, fully adjustable. Great part, but at almost $150 not cheap.
Old Nov 28, 2007 | 01:14 PM
firestorm's Avatar
05134NOS
is this a good one to start with?
15972nos , is this the window swithc you speeak of joe?
so this switch and a universal wet kit, do i have this right?
05130nos this one looks like a universal on that you would use with the window/rpm switch...
i am going to look into venom tight now too.
Old Nov 28, 2007 | 03:22 PM
skymynx's Avatar
damn joe we really do have the same setup lol. im getting the P.O.D. system (pressure on demand) in a few weeks. should clean everything up a bit
Old Nov 28, 2007 | 05:44 PM
05134NOS
Yes, you are right. I was just guessing on the number, but that 15972 is what I used on the truck and its awesome, super easy to use, really adjustable and simple. Just a little pricey, but when you consider the functionality, its worth it.
You used the window switch or you have it manually triggered?
Last edited by ItalianJoe1; Nov 28, 2007 at 05:44 PM. Reason: Automerged Doublepost
Old Nov 28, 2007 | 05:48 PM
skymynx's Avatar
[QUOTE=You used the window switch or you have it manually triggered?[/QUOTE]
manually triggered. i like it that way for the street anyways
Old Nov 28, 2007 | 05:50 PM
Me too, since I don't spray in first or usually in fourth, its a lot easier for me to squeeze it when I want it. People can say what they want, but it works for me and I won't blow the car up.
Old Nov 28, 2007 | 09:55 PM
skymynx's Avatar
exactly. when i use it on the streets its usually in 2nd or 3rd. 4th is just a waste in my opinion. no real need for it at that speed.
Old Nov 28, 2007 | 10:01 PM
  #36
cooljake73's Avatar
my questions is spraying the zex wet kit how bad is that on ur engine like seriously if i only run it on the track and maybe a few times to blow some serious cars away will it fry my engine or what im not no nos expert at all i know diddly **** bout it
blow cars away in the streets i meant
Last edited by cooljake73; Nov 28, 2007 at 10:01 PM. Reason: Automerged Doublepost
Old Nov 29, 2007 | 01:29 AM
  #37
firestorm's Avatar
i was actually hoping to have the window switch ,and rpm switch, in fopr safety, and a hot button to ensurwe only when i want it on. i will be spraying meth at the same time, so i can keep my timing.
cant find much on a venom system, their site is down, and they seem to have a groovy computer controll. i do need to hurry up, as the car has to be complet ed over winter.
okay i have a theory for you, what if a guy went with a direct port wet kit, and used jetting to help compensate for our big mean old lean #4? i like the look of zex, but nos seems wat cheaper.
so hard to decide. but this theory, i would appreciate your input..... pretty please?
Old Nov 29, 2007 | 01:39 AM
  #38
The only problem with that is you would need a wideband in each exhaust runner to see how lean/rich they are and then correct it. Not a cheap or easy process, but it would work.
Old Nov 29, 2007 | 02:30 AM
  #39
firestorm's Avatar
i was thinking more of measuring each spark plug temp with a pyrometer......hmmm but a 4 bung header would be best. with a zillion in widebands. i only have 1 measly LM-1.
sure sounds like a pre-blower wet system would be fairly easy, compared to some of my hair-brain ideas.
Old Nov 29, 2007 | 07:02 AM
  #40
skymynx's Avatar
i wont lie there is an increased stress on your car. i wouldnt be that worried about it. as long as your not running to lean your fine. i typically try to run around a 11.2 when im on the bottle. just stick with a small shot and youll be fine
it would be alot easier to put it pre blower. good idea with the number 4 cylinder idea just not all that practical. just do a pre blower setup and youll be good to go.
Old Nov 29, 2007 | 12:37 PM
  #41
firestorm's Avatar
i run about a 11.2 currently now with some slight variance up to 11.4
i have a 2.8 and 60's. with intake and exhaust. now i just need time to get my diff, axles, and mounts all in. i hope to do better at the track this year. somehow doing almost 104 mph didnt seem too powerfull. kinda lame.
Old Nov 29, 2007 | 08:36 PM
  #42
cooljake73's Avatar
who you or me
Turbo Johnny
Feb 21, 2019 09:41 AM
dennis69
Oct 20, 2015 04:49 PM
How to Guide
57
Oct 15, 2015 11:56 AM
TylerJHowell
Sep 21, 2015 06:47 PM
Redspire
Sep 16, 2015 07:08 AM
