Question about running nitrous w/ stage 3
I am probably going to get stage 3, and I am wondering what I need to run nitrous on it? The ecu is supposed to adjust timing and fuel for it on its own, but I'm wondering how it knows that the nitrous is on? Obviously I need a bottle, lines, and a nozzle ... but isnt the stage 3 supposed to act as a window switch if it has control over the shot? I was told it starts spraying at wot over 3000rpm, and cuts it 500rpm before your set redline, but do you need the actual dry shot control chip from the full kit? I just want to know if I'm gonna have to buy a full kit or if I save alot of money off my set-up by just ordering the nessesary parts if the ecu can control everything itself and doesnt need a n2o controller or a window switch or tps swith.
I'd rather not hear speculation as to rather it should or shouldnt; I would like to hear from someone who actually has stage 3 and is running a dry shot with it. As allways I apreciate your answers and support, I'm just hear to learn. |
The PCM controls everything. All you need is a Dry 50shot kit. The PCM will give you a 12vdc out, which goes to the Nitrous plunger relay. The PCM will 'spray' from ~3500rpms to ~6000rpms or so.
http://www.crateenginedepot.com/stor...s-W57C196.aspx http://www.crateenginedepot.com/stor...P1724C196.aspx download the instruction sheet, it will answer mostly all your questions. |
Originally Posted by ItalianJoe1
Thanks bro, I understand where you are coming from, so I don't care what you do. I got told for two years that my 2.8/stage 1 setup was gonna blow up, it was slow, whatever. Eventually I learned to stop saying anything, as only the noobs will talk shit anyway. You see now why Area, LSJ and guys like them don't post details on thier setups? All it does is cause friction with the idiots who don't know any better. Just stay under the radar, and learn what you can. PMs are your friend if you really need to know something.
Joe
Originally Posted by CBodnar
ssdan apparently lost compression in his 1st bank. i don't think anything is wrong with my car (prays) i could go get it tested but feel it's a waste. he was running a 19fuel or 20fuel i know a lot less than me since i am running 22. i took your advice. i am on my 5th bottle. trust me i drive her hard. sprayed in neutral vs ssdan in between gears(neutral) mis shifted. and just let off of the NOS lol
i hope it keeps treating me well. i just don't why they don't listen when you ran it for a while and i've ran it prob as much as you did for the whole first year you had it? idk lol i use her a lot. just can't up the shot even though it's tempting. and wtf are they talking about selling a car to the dealership it breaking then having to go back and pay for it. that is a load of crap. you could even go to court on that one. once you sell your car or return it that is it. at least thats what i think. -Chris |
Hey CBodnar, how do you like the spray so far? I havn't been on here for a while, I bought a GTO and kinda left the balt to the side.
Originally Posted by RoelSS
(Post 2724723)
I hear ya on the boosting, I'm hitting ~21psi, I think I need a new gauge to know exactly how much I'm boosting.
(Post 2726772)
go call up a parts store and ask them. also for people who buy royal purple. go to a place to buy oil and check on the back of all them where the oil comes from. it comes from all the same place. royal purple doesn't give you more power. they just have a bunch of people selling there product good saying it does something but it doesn't. i don't think people realize that but whatever. most the people who know the truth don't try to argue it because fact is majority of people on here are 16-20. most of them believe what they see and hear and believe oil can make power. wrong. also regular vs. v-power. it is the same thing. you do not get any extra power. i've done both and maybe only thing is it can make the engine last longer? not sure. otherwise regular is fine to put in the car unless the car pings. you can call me crazy but these are facts. just like mobile-1 paid GM a lot of money to put mobile-1 on there oil caps for people who buy the car to think mobile-1 is the only oil you can put in the car. |
You mean you spray on 87 octane? Wow, speechless. I've been spraying since 19k, and its on 34k now, with no problems. I have a stock catless DP, and my OG stock pipe. When I removed my stock one, all I saw was a bunch of white residue from the spray. I changed out my clutch 4 months ago, only because when I ran it hard, the clutch felt soggy. To my surprise, the stock clutch and the new clutch looked identical. The only thing that realy needed replacement was the pressure plate and flywheel. Our cobalts use the disposable type that can't be resurfaced. I did keep the old clutch cause its still in good shape.
As far as oil, well, I use synthetic. So are you using conventional? True that most people are 16-20, after all this is a car made for the younger crowd. In to GTO forums, the majority of the commnunity are older than that. I'm trying to make time to get back on the dyno. I want to see how much power the CA header and Fidanza added. Hopefully I can get good number like yours.;) |
no. i use higher octane now. when i was stock i put regular in it. no point. i raced my friend he put v-power in his we switched cars mine was always the one that was in front and faster for some reason stock for stock. both 07's and both brand new off the lot. now i put v-power in it and use fully synthetic oil, but i don't care what brand it is. all of them come from the same place look right on the back of the damn oil container. lol
i was like most the people on here. i was about to buy royal purple then my dad said wtf u gotta be on crack. then proved me wrong in every way and now i realize it is all the same. fully synthetic = fully synthetic. all are the same. all come from the same place. also i am sorta happy i didn't go stage 3 cause i would of spent more money. also your dyno numbers 274 is that whp? and 306torque? |
that sounds better. Yeah, those are my dyno numbers. It made that on the 4th run. I'm scheduling in a new dyno run, fresh in the morning too see how good the numbers are now with the flywheel and shorty header.
The best thing about GMPP stage 3 is that if for any reason it detects knock or any malfunction, it automatically stops spraying. Plus it has a tune for 100 octane, which you can switch on/off and you can set your own rpm redline. What sucks is no AC. |
(Post 2753448)
Fix for no ac on Stage 3?
Post the links, man!
This is the only hesitation that I have about Stage 3. My car has to last, that's the only reason that I have against custom tuning and pushing the envelope in pursuit of unholy horsepower. I'll take the rish tune of the stage 3, and sacrifice a little hp for a little reliability. I understand it's all relative, but it helps me sleep a little better at night so I'm gonne roll with it! |
Originally Posted by Maetrix
(Post 2770481)
So heres a question... On the stage 3 setup, you don't have to spray before the MAF? The pcm already automatically detects?
Correct, after the MAF sensor.
hey my best time is 13.79@104 with the 50shot where should i be?
LMAO people crack me up.....
this thread is full of fail |
Originally Posted by bulls'ss
(Post 2776094)
Originally Posted by silentd
(Post 2776104)
(Post 2776115)
You're joking, right?
Agreed. |
Originally Posted by Try2k
(Post 2775273)
hold on now im not sure what you all find so funny. im just wondering how much a 50 shot would help. i have 2.6 pulley/42lbinjectors/header/ full exhaust/intake and run consistant 13.79 and im trying to decide to spray or not.
(Post 2789736)
(Post 2726772)
i have a smaller pulley than you, as well as the boost juice and i only see about 16 psi at wot.... check ur cat just to be safe, considering that your richness (if you have any) may be causing a clog....hence backpressure and higher psi... just a fair warning |
13.79 on 50 shot is not good. Should be in the 12's
Oops sorry should have read that better . Yea with a 50 shot you should be into the 12's |
