Safe?????
I was just wondering if anyone had a nitrous setup with a stage 2 tune? Im planing on doing a 50 shot wet...but i really dont want to blow anything up. i will have stage 2 soon do you think taht the a/f ratio will be ok if i spray on the stage 2 tune. If not wat should i get to make sure i dont blow anything up.
11.8 a/f, and you should be golden. Just be ready to make more than 50 at the wheels at some points.
The stage 3 is setup to handle that and then some, and nitrous will only help your intake temps get lower. Plus your running a larger pulley, so even more safety curtain.
Just triple check your connections, to a pressure test on EVERY line you run. Last thing you want is your car becoming a melted pile because one fitting leaked.
The stage 3 is setup to handle that and then some, and nitrous will only help your intake temps get lower. Plus your running a larger pulley, so even more safety curtain. Just triple check your connections, to a pressure test on EVERY line you run. Last thing you want is your car becoming a melted pile because one fitting leaked.
wel tahts good news....ive been hearing that the stage 2 tune runs rich so if i spray it should put me right where i need to be.( Thats wat you are saying right?). I like my warrenty so i dont want to have to get stage 3. Ive seen people on here running nitrous with stage 2, but i just want to be safe. Also...you are saying that running a larger pulley with nos is safer on my part?
Macgyver2484
Sep 2, 2015 05:44 PM
