spraying on a 07
i was just reacently told by some local jbody members that a 75 wet shot is way to much for the 2.2 and it damages rings but i know several members hear have that and have run through alot of bottles and have had no problems. i'm asking this bc i want to go 75 shot wet and now i'm confused because the said a 50 shot is the saffest shot to run so let me know what you think?
yes..basically..the more power you have(faster RPMS) the colder plugs you'll need...that's why you need them for n20..but if you're just like driving around town, gas mileage will be really bad and i think performance will too, i think it's supposed to be good on the highway though(higher speeds)
i'd put them in when you're using n20..take them out when you're not.
Colder spark plugs arent' good for NA cars unless running nos.
Colder Spark plugs help with keep heat away from the tip of the spark plug so it doesn't cause pre-ignition/detonation. There is no specific limitation of when you can and can't use it but if you go with a plug that is too cold, you can cause a loss of spark energy at the tip.
You can use colder spark plugs in many of situations but it's only in a needed case.
Naturally Aspirated vehicles CAN use colder spark plugs especially if they are generating alot of power to the point that pre-ignition is more likely to happen (example: High Compression Engines).
So going with a step colder plug isn't going to cause any serious issues.
Turbo Johnny
Feb 21, 2019 09:41 AM
