Nitrous Oxide N20
Tuning for a 50 DRY
Old May 3, 2007 | 10:18 PM
Blown 4-banger's Avatar
Tuning for a 50 DRY
As some of you may know, I blew my motor, and I putting it back together with north of $3000 worth of parts/work. The motor will laugh at 600 hp. At first I'm putting it back with the stock ported eaton. I will be around 400 whp on race gas with that set up, like many of the cobra guys I want to do a 50 shot of nitrous, mostly for cooling purposes. I want to do a 50 dry to keep it simple, but I've never tuned for nitrous. Should I just tune it to run uber rich OFF the spray?
Old May 3, 2007 | 10:20 PM
BriantheLion26's Avatar
I thought you said before you didn't believe in nitrous and would never use it?
Old May 3, 2007 | 10:22 PM
cobaltssTH's Avatar
i love how you just blew your engine and now your putting n20 and all this ****. if car ever gets going with all this it will bne awesome
Old May 3, 2007 | 11:45 PM
IonNinja's Avatar
yeah you nitrous hater...
well for one your off the bottle performance is going to suffer because you wont be able to run as much timing as you normally would but I'm sure you know that.
you know I've never actually thought of how you would tune for a dry shot. if you were running wet it'd be much easier IMO because you could just switch out the fuel jets to get the right amount of fuel needed under nitrous use.
Old May 3, 2007 | 11:53 PM
Shortbus's Avatar
It would be much easier for you to run a wet shot on the lsj, contact zinner, he should be able to give you some great info on this, he has been runing a 50sh0t, and 75 shot nicely.
Old May 8, 2007 | 12:45 PM
zinner's Avatar
Moderator Alumni
A dry shot would be interesting. The limiting factor would be max'ing out the MAF range and/or the P0068 CEL.
The dry shot is supposed to cool the MAF and make it believe it's drawing more air in, this would probably cause a P0068 CEL and limp mode after a point.
The PCM has no idea that a wet shot is happening so less chances of CEL/CODES.
This is just speculation. I believe there was a person running a 50 shot on a Redline ION, Derrickz28 ?? Obviously they would know how the engine reacts.
Old May 10, 2007 | 01:05 PM
1BADSS/SC's Avatar
I think the stage 3 kit runs on a dry shot
Supercharged06SS
Dec 11, 2022 04:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
