Nitrous Oxide N20
Wet Kits?
Old Apr 25, 2008 | 01:48 AM
redlineblueline's Avatar
Wet Kits?
Anyone running wet shots of nitrous on their cars? If so engine, pics if possible, and where your jets are located.
Old Apr 25, 2008 | 01:53 AM
HackAbuse's Avatar
If you look VERY CLOSELY you can see the jet on the bottom side of the intake to the right of the radiator hose
Old Apr 25, 2008 | 02:20 AM
so where are you connecting to the fuel lines for the wet system
Old Apr 25, 2008 | 02:23 AM
ItalianJoe1's Avatar
There is a test port on the fuel rail, remove the schrader valve and screw on the fuel feed line. Easy stuff.
Old Apr 25, 2008 | 02:25 AM
HackAbuse's Avatar
Yeah, look directly below the oil cap and you'll see the wire loomed fuel line coming off the fuel rail, its the line that has some electrical tape on it. Look closely
Old Apr 25, 2008 | 11:19 AM
lil_kano's Avatar
look in my gallery....
your a traiter hack. you selling your car...
Old Apr 25, 2008 | 11:26 AM
HackAbuse's Avatar
This was a good car for getting ***** in High School, but it's just not doing it for me anymore
Old Apr 26, 2008 | 10:20 PM
lil_kano's Avatar
well at least when i got my other car i kept the balt...
Old Apr 26, 2008 | 10:22 PM
anyone running a wet shot on an LSJ?
Old Apr 27, 2008 | 01:51 AM
I am...
Old Apr 27, 2008 | 01:54 AM
HackAbuse's Avatar
Originally Posted by ItalianJoe1
I am...
Yeah he's tearing people new ******** with it
you spraying pre or post blower? hows fueling/tuning?
Old Apr 27, 2008 | 01:56 AM
Pre, actually before the TB. No tuning for it yet, have some personal situations that need to be dealt with, then I'll start tuning it. On a wet shot, there shouldn't be any fueling issues.
Last edited by ItalianJoe1; Apr 27, 2008 at 01:56 AM. Reason: Automerged Doublepost
Old Apr 27, 2008 | 02:00 AM
widebody_balt_ss's Avatar
i spray pre blower. never had a problem.
i'm talking about starving the fuel rail, or causing any problems for the fueling/tuning of the engine from tapping the fuel line
Old Apr 27, 2008 | 02:02 AM
its a small shot and I'm on 42lb injectors. I'm not worried.
i was only asking because of the consensus on here that lack of fuel is causing the cylinder 4 problems
Old Apr 27, 2008 | 02:06 AM
HackAbuse's Avatar
If your worried about cylinder 4, switch to a return style fuel system.
I beleive there is a how to somewhere
Old Apr 27, 2008 | 02:09 AM
exactly why i am asking about fueling, if people are wanting to go return on stock blowers i just want to make sure a wet kit isnt going to take too much fuel out of the system, even though it is ending up back in the system in the charge air
Old Apr 27, 2008 | 02:15 AM
HackAbuse's Avatar
You can change the jets around when running nitrous so you can purposely run rich
Currently I'm running a .044 nitrous and .021 fuel jet. I should be running like .024 fuel jet, but the stock PCM runs the car rich, so I'm purposely leaning out the mixture.
Old Apr 27, 2008 | 02:18 AM
alright heres what i was scheming:
spray after the blower almost in a direct port setup instead of a single jet...and run a dedicated fuel line with its own pump and filter from the tank
Old Apr 27, 2008 | 02:23 AM
I plan to go return before pushing the car further, but the drain from the current setup should not be too great. I've done bigger shots on two other LSJs near me, (75 and a 90) and they both run great and have for some time now.
Old Apr 27, 2008 | 02:25 AM
yeah i'd love to run something similar to this
Old Apr 27, 2008 | 02:26 AM
Similar to what I have in another car. My jets are smaller though.
What is the base fuel pressure on the 2.2? I know the LSJ is much higher than what the jets are set for, meaning that if they say to use a .21 jet, they are figuring on 42psi fuel pressure. Our cars run about 58psi or so, meaning that it will be rich or you need to use a smaller fuel jet to get the correct mixture.
Damn, I think I'm going to make one of those for myself, thats awesome.
Last edited by ItalianJoe1; Apr 27, 2008 at 02:26 AM. Reason: Automerged Doublepost
Old Apr 27, 2008 | 02:28 AM
it is an awesome piece, might have to do a little rigging for blower fitment
