Nitrous Oxide N20
WOT switch question.
Old Jul 15, 2008 | 09:50 AM
SSdan's Avatar
My kit came with a WOT switch to activate the system. I couldn't find any place to mount I'd nor any way to mount it on the pedal. Right now the way it's setup is I have extra wire so that I can pull the swich out from underneath the cupholders and activate like a push button system.
I'd much rather have it the way it was intended on the pedal but I can't seem to figure out a way to mount it.
How are you guys mounting the switch on your cars?
Old Jul 16, 2008 | 11:56 AM
Kibosh3's Avatar
i epoxied it to the shaft on my peddle...very clean install and stays right where it should.
Old Jul 16, 2008 | 02:42 PM
Spanky's Monkey's Avatar
i'll get pics of my install later its pretty straight forward. post em up later when the wife gets home with the car and if you're interested in a zex electronic tps pm me i'm not using it and i want it outta my tool case, makes install hella easy, it just wires into the current nitous system and your tps wire on the tb.
Old Jul 16, 2008 | 02:43 PM
hatrickstu's Avatar
careful glueing stuff to your shaft bro, thats risky business
Old Jul 16, 2008 | 02:47 PM
originaladrian's Avatar
didnt want to use a window switch?
Old Jul 16, 2008 | 03:17 PM
i have a window switch in-line.
i just don't like the electronic tps i like the mircoswitch under the pedal. it's a little more old school electronics in my taste.
Old Jul 16, 2008 | 05:40 PM
Kibosh3's Avatar
same...the tps makes me nervous... i click the pedal - the nitrous shoots...thats the way it should be
Old Jul 16, 2008 | 05:57 PM
SSdan's Avatar
Great. I was actually thinking of JBwelding it to the pedal.
Kibosh, can you please get me a picture showing the position?
Old Jul 16, 2008 | 09:24 PM
Kibosh3's Avatar
for you- anything lol... post a pic in a few.
bang
By kibosh3, shot with N95 8GB at 2008-07-16
forgive the photo's not very much space in there to angle the camera....hope this helps...and i can assure u that its sturdy, and only clicks on that final little travel of the pedal...total control
and i know its kind of a mess, but i have ALOT of mods to my car that needed wiring, my next order of business is to cover those properly...i hate wen things don't look clean.
Old Jul 16, 2008 | 09:41 PM
this is my install
Old Jul 17, 2008 | 08:50 AM
SSdan's Avatar
Sweet. Thanks both of you.
Old Jul 17, 2008 | 11:01 AM
IonNinja's Avatar
i'd be scared to kick that thing outta the way and have it not engage at WOT
i'd use it with cable throttle though...just put it on the TB, much easier
Old Jul 17, 2008 | 12:00 PM
that's the point for me if i get rear-ended on a cruise or in an accident where my foot is still on or over the throttle the swtich will move disabling the system. i thought about that long and hard.
Old Jul 17, 2008 | 12:10 PM
batboy's Avatar
I have a Nitrous Outlet RPM window switch with a built in TPS WOT switch and it works great. Every nitrous system should have a window switch. I originally bought a micro switch to use as a WOT switch because I wasn't sure whether to trust the electronics, but I never installed it because the window switch works so well.
Old Jul 17, 2008 | 12:28 PM
you're making that last statement as though all window switchs have the tps built in. the window switch is not the component that prevents you from spraying at wot only its the tps or micro-switch. i agree every nitrous system should have a window switch they should also have some sort of wot switch whether it be electronic or mechanical.
Old Jul 17, 2008 | 12:39 PM
Kibosh3's Avatar
u would be suprised...the epoxy has it on there very well...and it would be a miracle to wedge my foot in that lil space where it sits- let alone have enough force/grab to move its position .... ive tried with my hand..very sturdy
Old Jul 17, 2008 | 01:24 PM
batboy's Avatar
Yeah, I hear what you're saying brother. It's true not all window switches have a TPS switch. To be perfectly clear, a nitrous system absolutely should have a WOT switch. I also highly recommend using a RPM window switch. If you miss a gear and over rev, a window switch will shut the solenoid off and prevent damage when you bounce off the rev limiter. You also should not spray under 3,000 RPM either. If you are putting a system together, I suggest getting a window switch with a TPS WOT switch built-in already.
Here is the window switch I have and heartily recommend if you are in the market for a new one.
http://www.nitrousoutlet.com/catalog...product_id=964
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
TylerJHowell
Sep 21, 2015 06:47 PM
