North Central ND, SD, MN, and WI
Minnesota Chat 2011
Old 07-22-2011, 10:11 AM
  #226
Ryze's Avatar
Originally Posted by 007CobaltLS
A little help here...those of you that tune maybe can answer better.
I have a P2A01 code...I know it's a faulty circuit at the secondary 02 sensor.
My question is this, what code is thrown when you have an aftermarket header? I was wondering if that is the same code or if the code thrown for that is from the first 02 sensor?
Is my secondary 02 sensor probably bad? I have no problem going and picking one up and replacing it to see...will probably do that this weekend, just wanted to make sure it's not the same code that is thrown for a header...because my tune has that code deleted and I want to make sure it's not an issue with my tune.
Actually now that I think about it...gas mileage is down a little, sounds a little rougher in the exhaust...wonder if the sensor is bad or if it somehow got disconnected or something...I'll have to jack it up this weekend and see.
Might not be going to Warrior Dash...for some reason I'm just not in the mood...what day and time are you going Parnell and Jeff? I'm supposed to be there Sunday at 3:30.
Circuit/System Testing
Important: All modules must be powered down or misdiagnosis may result.
Ignition OFF, disconnect the scan tool and wait 60 seconds to ensure all modules are powered down.
Ignition OFF, disconnect the harness connector at the appropriate HO2S.
Ignition OFF, measure for less than 5 ohms resistance between the appropriate HO2S low signal circuit terminal A and ground.
If more than the specified range, test the appropriate HO2S low signal circuit for an open/high resistance. If the circuit tests normal, replace the ECM.
Ignition ON, verify the appropriate scan tool HO2S parameter is approximately 450 mV .
If more than the specified value, test the appropriate HO2S high signal circuit for a short to voltage. If the circuit tests normal, replace the ECM.
If less than the specified value, test the appropriate HO2S high signal circuit for a short to ground. If the circuit tests normal, replace the ECM.
Ignition ON, install a 3A fused jumper wire at the HO2S high signal circuit terminal B. Toggle the jumper wire between the HO2S low signal circuit terminal A and battery voltage. Verify the appropriate scan tool HO2S parameter toggles between 0 mV and approximately 1,000 mV .
If the appropriate scan tool HO2S parameter does not toggle correctly, test the HO2S high signal circuit for an open/high resistance. If the circuits test normal, replace the ECM.
If all circuits test normal, replace the appropriate HO2S.
Ryze is offline
Old 07-22-2011, 06:16 PM
  #227
09TcSedan's Avatar
Originally Posted by eddi
damn didnt know that someone killed someone, been out of state for awhile while in the service, yeah ive been down there maybe 2-3 times this summer, most of its just meet up there and head out somewhere else. its nothing like it used to be back in 04-06.
yea,it was crazy. this girl was on vandalia (where the last big bust was) and there was a bunch of people there and this chick flew down vandalia and blew a red light doing about 80mph and hit this guy on the corner waiting for the bus. **** was crazy. but it sounds like last weekend there was some decent racing goin on.
hopefully the weather holds out and we can witness some
09TcSedan is offline
Old 07-22-2011, 06:47 PM
  #228
eddi's Avatar
I'm sure it will, also planing on going to the fair grounds tomorrow to with the wife and friends
eddi is offline
Old 07-22-2011, 09:42 PM
  #229
007CobaltLS's Avatar
Thanks Ryan, I will look into that. Now for some reason it's been off all day today though...strange...I'll climb under there and see if anything is loose or what is going on.
007CobaltLS is offline
Old 07-22-2011, 11:39 PM
  #230
eddi's Avatar
Shout out
Hey if your available get over here to the holiday off 280 need more Balts out here.
eddi is offline
Old 07-23-2011, 01:25 PM
  #231
Ryze's Avatar
IIRC that code is a rationality check code. basically checking to make sure the sensor does what it needs to do in an allotted time.. I'd probably just replace the sensor
Ryze is offline
Old 07-23-2011, 07:42 PM
  #232
slobaltzzp3's Avatar
i used to go out there all the time but kinda faded away from that, my buddies try to get me to go too. i kinda want to get out that way again because of all the new fast projects coming out of the woodworks.
slobaltzzp3 is offline
Old 07-24-2011, 03:21 PM
  #233
hoffa's Avatar
oh hai
Ryan = the awesome, gives really good reach-a-rounds.
hoffa is offline
Old 07-24-2011, 08:29 PM
  #234
nhanson's Avatar
Powercruise was ******* awesome!
bryce was there and another yellow cobalt with a CF hood
nhanson is offline
Old 07-24-2011, 11:04 PM
  #235
Ryze's Avatar
Originally Posted by hoffa
oh hai
Speaking of.. Your car done yet? I got an itch to tune!
Ryze is offline
Old 07-25-2011, 11:19 AM
  #236
hoffa's Avatar
no... there was a "mishap" with UPS, someone was stealing boxes and mine containing my pulley assembly happened to be one of them. I was told that the box was found and it was shipped back to the seller. Seller said he shipped it out over the weekend.
hopefully i get those soon.
then i have to get a new H/E, cuz rolling around w/ the leaky one i have now is stupid.
sad
hoffa is offline
Old 07-25-2011, 05:08 PM
  #237
nhanson's Avatar
all you MFers better be at powercruise next year
nhanson is offline
Old 07-25-2011, 09:40 PM
  #238
Shobalt_2008's Avatar
Hey nhanson sorry i couldnt make it i was down at carcraft summer nationals this year. And also Ryze what kind of tuner are you and how much is it for a tune, i would really like one so i can beat more people around here
Shobalt_2008 is offline
Old 07-26-2011, 12:26 AM
  #239
Ryze's Avatar
lol. I can tune cars.
Ryze is offline
Old 07-26-2011, 02:29 AM
  #240
06_ion2's Avatar
oh hai!
06_ion2 is offline
Old 07-26-2011, 07:31 AM
  #241
nhanson's Avatar
yea hopefully next year they will be different weekends.
Driving the **** out of your car>looking at cars
nhanson is offline
Old 07-26-2011, 08:34 PM
  #242
Hey ryae what kind of tuner. HP trifecta what up? And how much. Yeah could be but I was looking at the classics I wanna get. I can't afford it if car breaks lol
Old 07-26-2011, 08:55 PM
  #243
Ryze's Avatar
HPTuners..
PM me if you want details.
Ryze is offline
Old 07-28-2011, 10:48 PM
  #244
Ryan, I'm going to have you do the following for me: front sway, new header, new dp. Also, if you can check to see if my cat-back has a leak in it (possibly patch it up) and lastly, replace my the second 02 sensor for me.
I know these aren't hard to do, but I'm lazy and would rather pay you. LOL
I'm ordering everything online right now and will let you know when I get it in. After I get it all, we'll figure out a day/time for you to do the work.
Thanks I appreciate it.
Old 07-31-2011, 03:49 PM
  #245
PRND3L's Avatar
Anybody live near Esko Mn????
PRND3L is offline
Old 07-31-2011, 09:36 PM
  #246
northvibe's Avatar
why is there a prostitute you want me to try?
northvibe is offline
Old 08-01-2011, 07:47 PM
  #247
PRND3L's Avatar
Yup, 44 years old:
PRND3L is offline
Old 08-04-2011, 07:41 PM
  #248
09TcSedan's Avatar
anyone around saint paul know where to get GOOD premium gas? it seems like every gas station i go to has shitty 91 octane gas. everyone says shell gas is amazing and stuff but i found 1 shell gas station and it has 91 octane gas! i have to run premium so i was just wondering if anyone around saint paul know where to get good gas?
Old 08-04-2011, 09:59 PM
  #249
ecotecturbo's Avatar
Bp 93 works good.
ecotecturbo is offline
Old 08-04-2011, 10:15 PM
  #250
RHZ
RHZ's Avatar
bp 93 everywhere in minneapolis.
RHZ is offline
Quick Reply: Minnesota Chat 2011
