Starter?
well I would forget the clutch solenoid because if you hear the starter clicking you know that there is some power getting to the starter. if the clutch solenoid was bad there would be no power getting to the starter. Turn the key and don't push in the clutch and nothing will happen and then push in the clutch and you will see the difference...
It's either the battery (my money is on this), the starter, or both...
yea just pull the battery and take it to the local auto parts store and if they say that it's good than pull the starter. However if it turns out to be the starter I would call off work and get it towed to the dealer rather then spending $100 on something that's covered under warranty.
If you bum a ride call a tow truck tomorrow and get it towed to the dealer so they can fix it on Monday. and if they have to keep it over night on Monday they have to give you a rental car...
Like everyone else said, it's your battery. with a dead cell you can run your accessories, but you won't have the cranking amps to turn over your engine. That clicking you hear is the solenoid engaging the starter gear but not turning the engine over. When you try to start it does the lights get dim?
dont remember, I can check real quick
Yes the headlights turn off when I try to turn it over, and they dim a lot when i open the door
Last edited by 06 Cobalt_SS; Jul 13, 2008 at 03:56 AM. Reason: Automerged Doublepost
hmmm and why cant you push start it?
try pushing it harder, get a friend to help
and POP that clutch. unless you dont have enough power to power your spark plugs????
weird that you cant push start it.
yeah definitely battery. also, a lot of dealerships (around here at least) will give you a rental, so I would make a stink about a "newer car having a dead battery, yadda, yadda" and they'll probably give you a rental. I'm a retail manager, and I can honestly say, when you have a nasty customer in front of you pissing and moaning, more often than not you just them what they want so they shut up and get out of your face.
I hear ya, im probly gonna get a new battery tomorrow so i can save myself the aggrivation of having to bum a ride in the morning and then picking the car up from the dealership, and dealing with them again
Well, I dont really feel like having to crawl under my car to take the starter off. ( It doesnt even clear curbs, so its not gonna get high enough for me even jacked up)So I hope its just the battery.
Well, I took it down to the parts store, and the battery is good. What shbould be the next thing i check in yalls opinion?
Last edited by 06 Cobalt_SS; Jul 13, 2008 at 02:18 PM. Reason: Automerged Doublepost
