Stupid sunshine
Not so much into porting but I am thinking about getting HP tuners so I can start tuning. I really did not plan on "modding" this car so much...but if I keep going like this a tuning program is going to be a necesity. I might try to offset the cost of the system by unlocking all Cobalts and tuning other's cars.
Going FI yourself or part of a kit? If you are doing it yourself a tuning program would be very worth it.
Wingless right? the Carbon fiber stuff looks awsome for the Cobalt. An Orange tint clear coat would be sick! I am happy to hear that you are going to be keeping the Cobalt...an EVO or STI would of been cool though.
Ordering a cheap Oil Catch Can and a Coolant Reservoir tonight.
think the next thing Ill be buying for the balt is going to be a carbon fiber trunk and then the oem carbon fiber hood. (beings theyre fixing the damn thing)
See about 2 a week on there. Worse part is getting the download from the dealership. they are going to try to screw you unless you know someone or come in very prepaired. GM is not doing bad because of the cars it sells or the prices...it is the dealerships that is F*@cking the corperation up.
im not sure what do you think i should do lol
check crate engine depot i know there stage II is cheap
Yeah, this was even cheaper. A guy had two of them listed starting at $400 each. The one I lost ended up going for $500. Theres another one on there for $355 right now. I'll keep an eye on it and see where it goes.
Now I just gotta find all of the parts!
Tuning will be a must, and I am leaning toward HP Tuners, but it would be way cooler to buy one and all use it. I figure once I get everything dialed in I should be good for a couple years. Well at least until I decide to build up the motor and turn up the boost that is!
Originally Posted by 06 SS S/C
06' SS2SS, I will check those out. I remember seeing some gutter guards, but they didn't look wide enough. Do you remember the size yours were that you bought??
Def. Wingless..... im going for the whole orange and "black" look... i know carbon fiber isnt black, but its real close in the dark.. the reason for it is Im one of those halloween fanatics! I might even get the custom plate oct 31 or trkRtrt.... prolly trkrtrt.... anywho if i go with the 2.8 pulley do i need bigger injectors or will that stage 2 ones work?
From what Ihave read 2.8s are just on the "not safe" side of the line. I have a 2.85 that is just barly on the "safe" side. 2.9 is perfectly safe. If you went with 60lb injectors you might as well get a 2.7" or smaller pully.
GM stage 1 and stage 2 have the same tune. So unless you want the stock stage 2 pully you realy only need the Injectors, harness (that you can make yourself with a cheap kit), and tune from stage 1. Then just pick up a belt and the pully system you want!
Getaway_Driver
Sep 8, 2015 09:41 AM
