Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Tvs Gb?
Old Feb 4, 2009 | 09:01 AM
  #726
Rydis's Avatar
Originally Posted by ls1fbody
hooray for sticking SC.
yeah, i have the 100,000 mile warranty on mine, but i'm not worried about the drivetrain. I'll use the warranty for stuff like onstar and interior components
same here, except I am paying for the warranty so I might as well use it...this is a great deal though
Old Feb 4, 2009 | 09:07 AM
  #727
red_line_cobalt's Avatar
ott are you guys online?
Old Feb 4, 2009 | 09:09 AM
  #728
scott allen's Avatar
Does anyone here think 20 psi is to much boost for are cars?The tvs comes with a 20 psi pulley.
Old Feb 4, 2009 | 09:10 AM
  #729
ls1fbody's Avatar
Haz l33t wheelz.
their little green light isn't on, so i would guess no...
not if the correct supporting mods are installed, or if the tune is correct.
Old Feb 4, 2009 | 09:12 AM
  #730
I heard its a direct bolt in you dont have to change anything except tune,injectors.Is this true,the wiring be ok.
Old Feb 4, 2009 | 09:14 AM
  #731
ls1fbody's Avatar
Haz l33t wheelz.
yeah, the only thing for wiring is possibly the TB upgrade.
Old Feb 4, 2009 | 09:15 AM
  #732
i have built internals so i plan to run 20psi.
Old Feb 4, 2009 | 09:17 AM
  #733
would 20 psi be safe with stock internals ? Our should i get the 85 mm pulley at the 17.5 psi level
Old Feb 4, 2009 | 09:18 AM
  #734
ls1fbody's Avatar
Haz l33t wheelz.
I'll run 20 and see how long it takes to go, haha. shouldn't really be that big of a problem.
  #735
does the 80mm pulley run 20 psi?
Old Feb 4, 2009 | 09:19 AM
  #736
Yes.
Old Feb 4, 2009 | 09:22 AM
  #737
and is that what the harroop comes with?
nvm i just looked and answered my own question
Last edited by red_line_cobalt; Feb 4, 2009 at 09:22 AM. Reason: Automerged Doublepost
Old Feb 4, 2009 | 09:25 AM
  #738
It comes with a 20 psi pulley,idont know why i think that is dumb,because most people wont run that much psi it should come with the 85 mm pulley thats 17.5 psi.You should have a opition on what pully you get dont ya think.
Old Feb 4, 2009 | 09:29 AM
  #739
thought's Avatar
Originally Posted by 06 pursuit gt
Updated the list.
35- 06 pursuit gt- Deposit Made
Glad to see you on here man. We can make the prairies proud.
Old Feb 4, 2009 | 09:30 AM
  #740
lsjwannabe's Avatar
Why is that? the 3.1 is perfectly safe?
Old Feb 4, 2009 | 09:32 AM
  #741
yeah, but can it run 20 psi safely with our motor stock? it doesnt get the heat which i know first hand that what ***** up our stock pistons haha. i wonderwhat a motor with a built head, anddimond pistons could safely run.
i have a ported head, with dual coil valve springs, cams, cometic head gasket, ARP head studs, diamond pistons, total seal rings, performance piston pins and clips, and custom ARP rod bolts built for more rotating pressure, and more RPM.
Old Feb 4, 2009 | 09:33 AM
  #742
the 20 psi pulley is safe on stock internals? If so that would be realy cool id love the extra power if it was safe
Old Feb 4, 2009 | 09:34 AM
  #743
lsjwannabe's Avatar
I personally ran 28 psi on stock internals, i think you will be fine
  #744
williamhvx1's Avatar
2X ????
Old Feb 4, 2009 | 09:35 AM
  #745
lsjwannabe's Avatar
see above post
Old Feb 4, 2009 | 09:37 AM
  #746
Damn ,how much power was it making. I hear good thing about you so if you say its safe im ok then ,i just never heard of anyone running 20 psi on cast pistons,that is what we have right?
Old Feb 4, 2009 | 09:39 AM
  #747
how much should i run?
  #748
lsjwannabe's Avatar
We have hypereutectic piston's, they are pretty darn strong for being a oem unit.
336 whp on pump gas and the 2.75" at 25 psi
the 2.5" required race gas to be run effectivly
20 psi (80mm) is a great starting point for everyone here, the tvs is a very large upgrade and will totally change the feel of your car. For most that will satisfy if any one wants to pulley down you can down the line and it's only 50~55 a pulley
Old Feb 4, 2009 | 09:43 AM
  #749
What about the ls4 tb is it a direct bolton no wiring issues,and can i buy it from you,and any thought on the ls4.how much it would cost,thanks.
Old Feb 4, 2009 | 09:46 AM
  #750
lsjwannabe's Avatar
The ls4 is a direct bolt on, the tvs inlet was made to mate with it if you so choose. You can usually pick one up cheap online or from a junk yard. There are gains to be had with it, but it does make your throttle much more sensitive. Some of this can be tuned away but for most its more of a hassle then it is worth due to daily driving and what not. I personally ran a ported ls4 unit and picked up 13 whp and 10~11 wtq across the board. Like i said though this mod is not for everyone.
