Wanted 60lb Injectors, Heat Exchanger, 2.7 Pulley
Hey I am looking for a Heat Exchanger, 2.8 Pulley that fits stage 2, dual pass;
what I am wanting to spend.
2.8(stage 2 compatible)---- 40 shipped
Heat Exchanger(with all mounting and routing hardware)---- 100-150 shipped
dual pass(GM or ZZP)---- 50-100 shipped
Let me know if you have any of these, thanks in advanced!
Eh I think that a 2.6 would be a bit to much for my car right now, I was thinking the lowest I am going to go on the stock m62 is going to be 2.7. Do you know how much boost you get with a 2.6?
I'm not sure, but I don't believe it would be much difference in boost between the 2.7 and 2.6. Just make sure you read your wideband and tune it where you're not running lean. There's also a good HOW TO on porting and polishing the inside of your m62. The boost psi goes down doing so, but makes boost up time a lot faster.
patooyee
Oct 1, 2015 01:07 PM
